Belts covered under warranty???
Old Feb 2, 2007 | 08:32 AM
infini_'s Avatar
Are drive belts covered under warranty?? My 05 G has only 27k.... and it seems like they need replacement already. Its 187.50 for the belts.
Old Feb 2, 2007 | 08:41 AM
sdnpaul5at's Avatar
No that's wear and tear, your belts should be fine, are there any cracks in the belts? If you still have bumper to bumper warranty and you have a defective belt, then I would say yes, they should cover it.
Old Feb 2, 2007 | 10:00 AM
bluestacy04's Avatar
I just changed my yesterday @ 49k and the PS/Alt belt only had three ribs instead of the four it was supposed to have. Its not to hard to change them out though!
Old Feb 2, 2007 | 12:26 PM
ttrank's Avatar
Grocery getter
27k is a bit low but it depends on your conditions.
Also $187! You can buy new Gates or Gatorback for ~$40 and DIY in an hour with a few wrenches, ratchet and sockets.
Old Feb 2, 2007 | 01:00 PM
Eric@TCGMiami's Avatar
The biggest mission is taking off the under body plastic cover.... after that its cake... all you need is a 10Mm for the plastic cover, a 12MM for the tensioner and a 14MM for the pulley..... should take you no more than 30 minutes ..... While talking
Old Feb 2, 2007 | 01:20 PM
ttrank's Avatar
Grocery getter
And drinking beer.
Beer makes any toolbox complete.
Old Feb 2, 2007 | 03:59 PM
infini_'s Avatar
Thanks guys....
Car was in for having the alternator bearing change..... i asked him to leave my belts alone.... you are right... they should be fine.
I think he was trying to get me to change them as they were off anyways....
I was not falling for that.
Old Feb 2, 2007 | 04:14 PM
ttrank's Avatar
Grocery getter
They always try to get you to change the belts while they are in there. If it was cheap ~$50-60 I would do it but for that much they better take you to dinner first and use lube after!
Old Feb 2, 2007 | 04:23 PM
infini_'s Avatar
listen to this....
he just called me up to tell me car is ready.... and told me dont worry about your belts.... they are not as bad as we thought....
im confused.... in the morning he was giving me pitch to change it.... STEALERS....
Old Feb 2, 2007 | 06:33 PM
BigSash's Avatar
Originally Posted by infini_
listen to this....
Was your car at the stealership or third party?
The belts are manually adjusted so they often just need a bit of a tightening.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
dseet
Oct 11, 2015 12:40 AM
