Would You Rather??
Would You Rather??
I am in a bit of a dillema here......I dont know if I want to go...
20x9 +35mm offset with 245-35-20 all around (CHEAPER)
19x8.5 + 35mm offest with 235-35-19
19x9.5 + 45mm offest with 265-30-10 (STAGGER, MORE EXPENSIVE)
counting in factors that
-more tire choices with 20's
-will be dropped on Z springs
-i like the fact rolling on 20's you can say you're on dubs.....
All opinons are welcomed and i really need them, please keep in mind i did search and i did a lot of research on my own....if these setups will not work please let me know what options i might want to consider....these are just packages i've put together for myself....thanks in advance guys!
ENVautoDetailing.com
20x9 with a +35 wont fit in the front. You'd need a +40 or higher and youd have to run some mad negative camber up front so they dont rub.
For the 19's, if you're only dropped on Z springs, i'd suggest going with 245/35/19 and 265/35 or 275/35/19 in the rear to fill up the fender gap.
-GP-
-GP-
Originally Posted by LuXXXz
LOL understandable
and i have to say
those sevas look SEXYYYYY on ur car
i had the s22s black orderd back in september and the wheel company was giving me the runaround and i cancled the order
and im still on the stock 17s
and i have to say
-GP-
