5AT fluid change (need advice)
Old Feb 21, 2007 | 07:10 PM
  #31
IP05G35's Avatar
You can use Castrol Multi Vehicle ATF it meets the full J-matic spec. It's also slightly cheaper but not by much.
Old Feb 21, 2007 | 08:59 PM
  #32
cooldog45's Avatar
I think I'm going to go with the Amsoil atf fully synthetic. Any one know how much diff fluid the g35 sedan takes?
Old Feb 21, 2007 | 09:05 PM
  #33
Noremac's Avatar
Originally Posted by cooldog45
... he said they do not perform such a service. they only drain and fill flush is not an option. wft is going on...
Guys, READ THE FSM!! The Infiniti specified procedure for servicing the 5AT does NOT call for flushing it out completely. For my 2004, the specs and procedure are:
-- Drain A/T fluid from drain plug and refill with new A/T fluid. Always refill same volume with drained fluid.
 To replace the A/T fluid, pour in new fluid at the charging pipe with the engine idling and at the same time drain the old fluid from the radiator cooler hose return side.
 When the color of the fluid coming out is about the same as the color of the new fluid, the replacement is complete. The amount of new transmission fluid to use should be 30 to 50% of the stipulated amount.
A/T fluid: Genuine Nissan Matic J ATF
Fluid capacity: 10.3 (10-7/8 US qt, 9-1/8 lmp qt)
In other words, you will only be replacing a fraction (30-50%) of the total (almost 11 quarts), which comes to somewhere between 3.3 and 5.5 quarts. Follow the procedure!!
Old Feb 21, 2007 | 11:37 PM
  #34
cooldog45's Avatar
This procedure is a lot easier said than done trust me I've done it like that on my old car and it was spilling everywhere. BTW if you do get to do this you can do it with two people and have one person keep the brake down and run through the gears this will help get more fluid out the converter, but def not all of it.
Pete
Old Feb 22, 2007 | 12:02 AM
  #35
Augy's Avatar
I got mine done today speaking of the devil. I noticed that the car grinds a bit when I start to take off and its fine. They said it might be the new fluid?
Old Feb 22, 2007 | 12:05 AM
  #36
abcquackyxyz's Avatar
for the read diff fluid you need about 3pints or 1 1/2 quarts.
Old Feb 22, 2007 | 09:32 AM
  #37
SilverII's Avatar
i have done the AT drain and fill 3 times already. I think it is easier than the oil change. Just open the drain plug, let it drain, reinstall with new washer, and refill oil. You dont have to deal with the underbody cover as with an oil change.
For me it takes 4 qt of J-matic.
Diff takes little more than 3 pints. (also easy DIY)
Old Feb 22, 2007 | 01:36 PM
  #38
cooldog45's Avatar
Just changed the diff fluid and almost 2 quarts went it. It was pretty clean but there was a lot of metal shavings on the plug. seems to be running a little smoother but its probably just me. will be doing the tranny drain and fill myself soon. F**k the dealers
Old Feb 27, 2007 | 04:38 PM
  #40
cooldog45's Avatar
So I went to Circle Infiniti in NJ and got the flush done. The receipt said they used 10 Quarts. I paid 199.95 for the flush, and car car shifts a lot smoother now. I had the 05 g35x loaner and I must say that it looks pretty empty inside. Seemed a lot slower than my 03 g35.
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
linedr89
Aug 17, 2015 05:11 PM
miata007
Aug 17, 2015 04:36 PM
NemesisGee
Aug 11, 2015 07:10 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
