Installation
Old Feb 21, 2007 | 09:57 AM
gway84's Avatar
Installation
Was just wondering how difficult it is to install tein h techs yourself. Thanks
Old Feb 21, 2007 | 10:01 AM
akuma's Avatar
very easy if you have the right tools. the rear is the easiest just the front that take the most time. took me bout an hour with a friend help.
Old Feb 21, 2007 | 12:14 PM
350.GT's Avatar
Like akuma said its easy just make sure you have compressor thats will help you alot. what kind of H tech did you get the G or Z. good luck with the drop. and dont forget to post pics...
Old Feb 21, 2007 | 02:16 PM
SFG356MT's Avatar
If you're not sure or don't have a friend that can help out you may want to consider having a shop install the springs. Are you riding on a stock sport shocks? Did you get the H tech for the G or Z? It makes a difference for your setup.
Old Feb 21, 2007 | 02:22 PM
gway84's Avatar
i have sport suspension on 03 sedan im not sure what to get 350z or g h techs, what do you guys recommend? ordering in next weeek or so. I do have knowledgable people to help me.
Old Feb 23, 2007 | 11:05 AM
SFG356MT's Avatar
How low did you want your drop and do you want a stiffer ride?
The Z H tech will give you a good drop (1in front and 3/4 rear) and they are stiffer than stock. The G H tech are a little softer for a more comfortable ride and drop is smaller (3/4 front 1/2 rear). I have a set of H tech for the G with only 600 miles if you would like to buy them cheap plus shipping.
Old Feb 23, 2007 | 05:20 PM
ttrank's Avatar
Grocery getter
As the guys above said, it's not hard, just make sure you have a spring compressor. That helps a ton. The old impact and towel wrap works but do it at your own risk!
Old Feb 23, 2007 | 08:01 PM
VQ Hotness's Avatar
I couldnt imagine how long it would take without power tools. GL .
Old Feb 23, 2007 | 08:09 PM
Dakkerz's Avatar
This thread has a nice write up
https://g35driver.com/forums/brakes-suspension-diy/104137-long-overdue-fix-my-diy-suspension-how.html
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
