potential leak?
Old Feb 22, 2007 | 11:43 PM
chinaman_87's Avatar
potential leak?
Hey guys I have a potential problem. I found a leak while I was parked outside of my gals house. The fluid was a redish color (transmission fluid possibly?) and it was located behind the d/s wheel well near where you jack up the car. The interesting thing is when I got home to check the location where the leak was, not even a drop. And another thing i noticed was that I think the same fluid was in the wheel well. I think that i might of hit a puddle of transmission fluid? Any suggestions?
Old Feb 22, 2007 | 11:58 PM
jack_burton's Avatar
sounds like power steering
actually i take that back could be brake fluid if it was by your wheel
Old Feb 23, 2007 | 12:02 AM
the wheel well was covered with the stuff. it wasn't dripping off the well but it was coated onto the well. Also there is no more leak.
Old Feb 23, 2007 | 12:06 AM
well the driver side area near the wheel is where the break fluid resevoir is. Pop the hood and make sure the resevoir isn't leaking. Than i would check the hoses running in and out of that. Then i would check that d/s wheel on the inside where the line attaches to the caliper.
Old Feb 23, 2007 | 12:07 AM
alright thanks for the tip.
Old Feb 23, 2007 | 12:17 AM
I just checked the brake fluid and its full and the color of the brake fluid is yellowish.
Old Feb 23, 2007 | 12:19 AM
check the power steering res. now, it's on the other side, the circleish container
Old Feb 23, 2007 | 12:30 AM
the lvl of the power steering fluid is b/t the min and the max point. I'm gonna have to take it to a shop tomorrow just to double check. Seems like it could be the power steering though.. Thanks for the help jack
Old Feb 23, 2007 | 03:15 PM
just went to put the car on a lift and the guy said that there was no leak and that most likely i hit a puddle. =)
Old Feb 23, 2007 | 05:16 PM
ttrank's Avatar
Grocery getter
Red is tranny (sometimes) or power steering fluid.
Just keep an eye out for more. He may be wrong.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
