Noise in back when speeding up
Old Mar 9, 2007 | 01:33 PM
fzr's Avatar
fzr
This does not happen all the time but sometimes when I speed up only when I press on the accelerator I hear this metal on metal sound coming from the back, as soon as I let go of the accelerator the sound is gone, when I accelerate again its back, I dunno could it be pad rubbing against rotor???
Thanks
Old Mar 9, 2007 | 01:55 PM
kvangil's Avatar
Sounds like rear brakes...I had a similar situation and I replaced rear pads/rotors. The noise went away.
Old Mar 9, 2007 | 03:00 PM
fzr's Avatar
fzr
hmmmmm I just checked my rear brake pads and they look like they have about 40% life on them. but it might be a warped rotor...
thanks for the input kvangil
Old Mar 9, 2007 | 03:04 PM
jack_burton's Avatar
i have that too, sounds like the differential or the transaxle going to the back of the car
Old Mar 9, 2007 | 03:21 PM
Chrlesmd's Avatar
If it's your rear brakes, you should be able to tell since the noise will change when you press the brake pedal. Is no change in noise, might be something else.
Old Mar 9, 2007 | 03:27 PM
VQ Hotness's Avatar
It could be yout exhaust Flexing and rubbing on something.
Old Mar 10, 2007 | 01:18 PM
fzr's Avatar
fzr
its a higher pitch sound, not exhaust for sure, its sounds like a ball bearing is worm out or something like that(but only when I accelerate)...I will bring it in to the dealer since the car is still under warranty. haha funny thing dealer told me if I get it checked out and the part is not covered under warranty, I have to pay for the actual inspection
Old Mar 10, 2007 | 01:25 PM
atlast's Avatar
if its metal banging against metal. its the brake system. go get it check =)
Old Mar 11, 2007 | 03:08 PM
fzr's Avatar
fzr
its not banging really its more like rubbing, only when accelerating(this doesn't happen everytime I accelerate) pretty weird...
going to dealer next week.
Old Mar 11, 2007 | 03:22 PM
cooldog45's Avatar
I get the same noise. Got a 03 sedan with a coupe mid and the heat shield removed. It def is not from the brakes or the exhaust, but I can not figure out what the hell it is. It sounds like a metal rattle. If you figure it out let me know.
Old Mar 11, 2007 | 05:12 PM
fzr's Avatar
fzr
see mine is not a rattle its a more of a (higher pitch metal rubbing noise...)
Old Mar 12, 2007 | 12:32 AM
cooldog45's Avatar
check the dust shields on the brakes in the rear it might be just that. They sometimes start to bend and rub a little check the clearance
Old Mar 28, 2007 | 03:37 PM
fzr's Avatar
fzr
when I was doing my service for a banging noise I told them about this noise in the back, they cound't hear it, they checked the brakes said they were fine, well at least the dealer replaced Front Compression Rods Left & Right
+ Front & Rear Stabilizer Links.
I will listen to the noise to become louder and bring it in again later on...
Old Mar 28, 2007 | 05:05 PM
mza4's Avatar
Any luck with this yet? I am hearing the same metal rattle from the rear, sounds like sheet metal rattling. It happens most often when I accelerate from a cold start.
Old Mar 28, 2007 | 07:44 PM
godmans's Avatar
check/search the TSB about clicking rear-axle
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
apintojr
Jul 23, 2015 10:52 AM
cyrus32
Jul 18, 2015 06:22 PM
