wheel bolt replacement
Old Mar 14, 2007 | 08:05 PM
louielou's Avatar
How difficult is it to replace wheel bolts? Reason: Installing 5mm spacers with extended bolts which were included in the package.
Old Mar 15, 2007 | 01:29 AM
02themax's Avatar
Just hammer them out one by one turning the rotor towards opening at the back. Pop new ones in then torque them down to make sure they are fully seated inside. Then install wheels.
Old Mar 15, 2007 | 02:33 AM
genge24's Avatar
so theres no need to take off calipers and brakes??? That saves a lot of time
Old Mar 15, 2007 | 03:02 AM
louielou's Avatar
Thanks for the quick reply. Im going try it out.
Old Mar 15, 2007 | 03:13 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
every time i've replaced wheel studs, i've taken off the rotors. There's less in the way and its easier to work with.
-GP-
Old Mar 15, 2007 | 10:19 AM
FenixL1P's Avatar
Trust me, you are gonna need to remove your calipers and rotors....it makes life so much easier...
Although it can be done, I wouldn't recommend using a hammer or any impact tools to pop the bolts out.... I used a large 3-prong heavy duty gear puller to press the lug bolts out.... you'll need more tools/items but you'll run less chance of cause unwanted bearing wear/damage.....
Old Mar 15, 2007 | 01:25 PM
louielou's Avatar
Oh...sooo....Im better off getting a mechanic to do it huh...I really don't have the time to remove disc and calipers and so on. I was looking for the quick method.
How about if I used a rubber mallet instead of a hammer?
Old Mar 15, 2007 | 02:31 PM
Jason@Riverside's Avatar
yes, remove your caliper and rotor...
besure to make sure the new hub bolts are seated properly in the hub...
Old Mar 15, 2007 | 06:22 PM
FenixL1P's Avatar
Rubber mallet is even worse at trying to get those studs out....
Pressing them out is the best for DIY... to pull them in, use a bunch of thick washers that barely clear the stud diameter and then use spare wheel nut to tighten studs....
Old Apr 18, 2007 | 01:51 AM
gesekee19's Avatar
So did you get this done already? how much did it cost you? i have to replace one of mine too...
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
si_driver
Jul 14, 2015 12:29 PM
