Hissing when car is off
Old Mar 15, 2007 | 11:12 AM
bowzer's Avatar
After i turn my car off there is a hissing noise coming from the front left of the engine, sounds like air coming out of a tire. Not certain if it's something to be concerned about or not?
Any ideas?
Old Mar 15, 2007 | 11:28 AM
RXM's Avatar
RXM
Thats the sound of your car being pissed that you were driving it granny style Your TPMS will alert you if your tire is losing air. I would just check the pressure really quick for piece of mind.
Old Mar 15, 2007 | 11:32 AM
bwassul's Avatar
that should be the intake relieving itself of pressure. the intake is pressurized during operation.
Old Mar 15, 2007 | 12:12 PM
Coach's Avatar
Not without a turbo or supercharger.
Old Mar 15, 2007 | 12:46 PM
Sir Boostalot's Avatar
The best thing you can do is get a rubber hose and put it up to your ear and search around for the noise. Its kinda hard to diagnose what going on unless you know where the problem is occuring. Good Luck......
Old Mar 15, 2007 | 12:53 PM
bwassul's Avatar
If the noise lasts a couple seconds, it's probably the intake. I get the same thing. If it lasts longer, you might have a problem....
Old Mar 15, 2007 | 01:51 PM
badtziscool's Avatar
Just air pressure equalizing between the atmosphere and the intake as the engine winds down.
Old Mar 15, 2007 | 06:23 PM
FenixL1P's Avatar
i get that hiss too... it must be the intake or something...
Old Mar 15, 2007 | 06:40 PM
ttrank's Avatar
Grocery getter
It's normal. The car is releasing additional vacuum.
Old Mar 15, 2007 | 07:20 PM
jiminy4DR6MT's Avatar
could be yourself relieving pressure?
BAAHAHAHAHA
ok sry i'm immature
my sedan does the same thing. only lasts a couple seconds though
Old Mar 15, 2007 | 07:21 PM
R2 V35's Avatar
Any ideas?
Did you check and make sure there is no snake under the hood?
chinee
Jun 10, 2024 07:48 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
