how to raise idle?
Old Mar 17, 2007 | 06:31 PM
TheTrance's Avatar
how to raise idle?
Does anyone know how to change the idle in a 03 sedan? mine is way too low and it almost shutoff today after i installed the HKS exhaust...
Old Mar 17, 2007 | 08:46 PM
chobble19's Avatar
not sure if this helps but i had mine bumped up using a cipher program.
Old Mar 17, 2007 | 09:14 PM
jjyellow's Avatar
I think only the dealer can do that. I've heard something about someone drilling a hole in the throttle body somewhere that raised the idle Nto real sure though
Old Mar 17, 2007 | 10:18 PM
chobble19's Avatar
def DONT put a hole in ur tb! and i highly doubt a dealer would mess with the idle...if anything theyll do it and tell u ur warranty is void lol
Old Mar 18, 2007 | 12:34 AM
joedaddy1's Avatar
try resetting ur ECU first!
Old Mar 18, 2007 | 12:36 AM
TheTrance's Avatar
I will try that and see what happens. thanks!
Old Mar 18, 2007 | 12:05 PM
Andy77's Avatar
Oh these modern cars! The last car I attempted an idle adjustment on was my new 1986 Miutsubishi Galant. I thought the idle was a little low, so I pulled out the shop manual to find the idle adjustment screws. I started reading the section on idle adjustment, thinking it would be like my other cars, outboards and lawnmowers I'd adjusted for years, etc. Step number one was "Insert your oxygen sensor into the tailpipe" and I knew I was out of luck, since no regular person had an oxygen sensor. I haven't adjusted a car idle since.
My dealer adjusted mine at the last oil change, but they have the right computers and other equipment.
Old Mar 18, 2007 | 12:40 PM
killerlexus's Avatar
if your idle is low, maybe you have a vacuum leakk somewhere.
Old Mar 18, 2007 | 02:12 PM
ttrank's Avatar
Grocery getter
I had the dealer up mine for me when they put in my new tranny with the UR flywheel. You need to have them do it.
Old Mar 19, 2007 | 01:31 AM
johnsonhuang's Avatar
wats wrong with having a low car idle? mines idle at 400ish, i like how it sounds like its off =)
Old Mar 19, 2007 | 12:59 PM
ttrank's Avatar
Grocery getter
I had to raise mine because it is easier to stall with a lightweight flywheel. Some also need to raise it for cams.
Old Mar 19, 2007 | 01:08 PM
TheTrance's Avatar
mine is way too low (100rpm) and when i rev it up and let it go it shuts off sometimes :/
Old Mar 19, 2007 | 01:17 PM
Neal376's Avatar
funny, always thought mine was too high. takes nearly a year for the ****er to warm up. if i turn it on and put it into gear, it will lurch fowards. i always need to let it sit for a minute or so after startup...thats why i am scared to hand the keys to valets etc. etc...
Marlin84
Apr 1, 2020 12:52 PM
vamarris
Sep 26, 2015 12:56 PM
Jnm07
Sep 5, 2015 01:16 AM
