Homelink problem
Old Dec 19, 2003 | 07:21 PM
bennyhana9399's Avatar
Homelink problem
For some reason homelink doesn't work with the garage at my new house! I've used it before, but for reason it doesn't work! I've tried at least 20 times. Has anyone else had this problem?
Thanks
Old Dec 19, 2003 | 07:37 PM
Msedanman's Avatar
O.F. Administrator
Re: Homelink problem
On the newer door openers with rolling code is a 'learn' button which must be pushed (at the right time) to activate the training mode to complete the install. My learn button is on the head unit up by the antenna.
<font color=red>G</font color=red>S<font color=green>M</font color=green>
<font color=red>G</font color=red>S<font color=green>M</font color=green> <font color=black>Silverstone Coupe</font color=black>
Old Dec 19, 2003 | 08:30 PM
ABQ_G35's Avatar
gsedanman is right, I had trouble with mine the day I brought it home, then realized my opener used the "rolling" code! This damn thing works better than the remote that came with the door, I can hit it a block away and the door opens!
Brilliant Silver/Graphite '04 Sedan/5AT
Old Dec 19, 2003 | 08:51 PM
Where do I find this "learn" button? Can you tell me the steps to take?
Thanks
Old Dec 19, 2003 | 08:53 PM
ABQ_G35's Avatar
I have a Genie opener, mine is inside the light housing, I can't remember the color of it right off hand, do you still have the manual for the opener? The G owners manual tells you how to do it, that's where if found how to do mine!
Old Dec 19, 2003 | 08:54 PM
I have a Genie also, but no manual. I have to open up the actual garage door opener?
Old Dec 19, 2003 | 08:56 PM
ABQ_G35's Avatar
No, try taking off the light cover, the one where you change the bulbs, seems my "learn" button is on the left side. Oh, and reset the Homelink before trying that BTW.
Old Dec 19, 2003 | 09:00 PM
Merlin's Avatar
Staff ALUMNI
Look for a little <font color=green>Green</font color=green> flat button.
Andrew, We Miss and Love You! Peace!
Old Dec 19, 2003 | 10:11 PM
GeoBau's Avatar
Cactus Hugging Admin
Or the <font color=red>Red</font color=red> flat one [img]/w3timages/icons/smile.gif[/img]
Go to www.homelink.com and check out the steps. You'll want to make sure you follow the instructions for a rolling code opener. Have you reset your homelink since you moved? Aw heck, here you go--
1.You need to erase the memory first (hold two outside buttons imultaneously)
2. Hold the desired homelink button and your garage door's remote opener button at the same time. Hold em for a LOOOONG time til it starts to blink slowly. It may blink quickly too, eh, I forget. Just hold it a long time.
3. Remove the light cover from your garage door's mechanical unit-- VERY easy. Press the flat button in there. Could be green, could be red, could be chartreuse, I don't know/care-- it changes from opener to opener.
4. Run back to your car (which is parked within about 20 feet) and press the button your just made learn the code earlier. Hold it down til your garage's light blinks (~3 seconds). If it doesn't blink, just keep holding it, and pray. Press it a few times after you release it to test it.
5. Sit down and have a beer.
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
Old Dec 19, 2003 | 10:51 PM
ABQ_G35's Avatar
<hr></blockquote>
I don't know about yours, but Genie has made it a PITA to change the bulb, things have to be unscrewed, my last opener, even though it was a very old one, all you had to do to replace the buld, was unsnap the light cover!
Old Dec 19, 2003 | 11:00 PM
GeoBau's Avatar
Sad... of the 6 I've programmed, so far they've all been easy snap-off covers. All were brand new doors, too. I hope they don't all start getting annoying.
G
Old Dec 19, 2003 | 11:18 PM
ABQ_G35's Avatar
GeoBau,
that is the one thing I haven't liked about the Genie, mine has two bulbs, and you don't remember one is out until you have the damned car in the garage, and it's almost impossible to get the cover off without moving the car! So, a lot of times I leave it until the other bulb acts up!
Old Dec 23, 2003 | 05:45 PM
gsg's Avatar
gsg
In addition to the sytems that require the "learn" mode, be aware that there are some systems that Homelink will not operate.
The development I live in has a gate that has some type of security even beyond that of rolling codes, and both the mfg. of the gate system and Homelink confirmed to me that Homelink will not operate it. Some mfg.'s will not disclose their codes to Homelink.
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
