Service engine soon
Old Dec 26, 2003 | 07:28 PM
MDGene's Avatar
Service engine soon
I have a small but annoying problem. Service engine soon notice got a habit to come on for no good reason, during regular driving. Recently it happened for the 3rd time. 1st time the computer was reset by the dealer, second time they "updated computer software" so it will not react to small leak from the fuel system, but it keeps coming back. It really annoys especially after dark.
Did anybody has similar problem?? Any thoughts
'03 Sedan/5AT?Desertplatinum/willow/sportpkg/14,2K so far
Old Dec 26, 2003 | 09:01 PM
Msedanman's Avatar
O.F. Administrator
Re: Service engine soon
not sure what would cause the light bro, but it should register a code that the dealer can retrieve with his 'Consult 11'.
If you have no mods, and the gas cap is on tight and not faulty, then it's a sensor or valve or something 'hidden' .
<font color=red>G</font color=red>S<font color=green>M</font color=green>
<font color=red>G</font color=red>S<font color=green>M</font color=green> <font color=black>Silverstone Coupe</font color=black>
Old Dec 29, 2003 | 08:39 AM
Chumbley's Avatar
Same problem - on second time with light in 5K miles.
Old Dec 29, 2003 | 02:43 PM
shunsuenli's Avatar
Recall Alert: INFINITI G35, INFINITI I35, INFINITI M45, INFINITI Q45, NISSAN 350Z, NISSAN ALTIMA, NISSAN MAXIMA, NISSAN SENTRA
Owner Notification Date: Dec 02, 2003
Number of Units Potentially Affected: 630000
Component Description: ENGINE AND ENGINE COOLING
NHTSA Campaign Number: 03V455000 Schedule an Appointment
Description of Recall Campaign: ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
DEALERS WILL REPLACE THE CRANK POSITION SENSORS. VEHICLES INVOLVED IN A PREVIOUS RECALL CAMPAIGN, 01V357, ARE ALSO INCLUDED IN THIS NEW CAMPAIGN. THE REPLACEMENT SENSORS USED IN THAT CAMPAIGN ARE ALSO AFFECTED. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING DECEMBER 2003. OWNERS SHOULD CONTACT NISSAN AT 1-800-647-7261 OR INFINITI AT 1-800-662-6200.
Old Dec 29, 2003 | 05:41 PM
Msedanman's Avatar
O.F. Administrator
Hi shunsuenli, Thanks for the data. You'll also find more info in this thread in our TSB/Technical Bulletins forum.
Cheers
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
poker_lamina
Sep 1, 2015 09:04 AM
03sedang35
Aug 29, 2015 07:56 PM
Ivan Duben
Canada
Aug 29, 2015 12:50 AM
igking
Jul 19, 2015 01:12 AM
