What can I do to improve handling on an 05X?
Old Apr 23, 2007 | 10:35 PM
nyclio's Avatar
Right now my car is stock. Nothing at all done to it. Everything facotry. (Tint doesn't count). What can do to my 05X sedan to improve the handling of it around curves at higher speeds so I don't feel like I'm steering a boat? It doesn't feel like it's on rails anymore...
Thanks!
EDIT: I would also like to improve braking if possible. And I live in NYC where there are monstrous potholes and bad snowy winters if it makes any difference.
Old Apr 23, 2007 | 10:38 PM
aam6906's Avatar
not much, springs, but itll still ride like crap
Old Apr 23, 2007 | 10:56 PM
ttrank's Avatar
Grocery getter
VRT has coilovers but I'm not sure if they are out yet.
For brakes, the best way is a big brake kit ($$$) followed by a larger rotor oem caliper kit like racingbrake ($$) with better pads and last go with better pads ($).
Old Apr 24, 2007 | 12:08 AM
RAYNYC's Avatar
my 04 x handles like a 78 impala with the original suspension too!
Old Apr 24, 2007 | 01:00 AM
Tunerz_Store's Avatar
Cheap brake upgrade is to find some 05-06 rwd sedan brakes or coupe brakes. Dual caliper with 12.6" rotor front.
Old Apr 24, 2007 | 08:14 AM
Neal376's Avatar
get the sedan or coupe springs. wilwood bbk. strut barrrr
Old Apr 24, 2007 | 10:48 AM
nyclio's Avatar
I don't even know what to look for. Would you be able to point me in the right direction; where/what to order, maybe even a good place to get it installed (brakes at least)? Also, does the fact that it's a G35X and not a regular G35 make a difference compatibility wise? Thanks!
Old Apr 24, 2007 | 01:46 PM
Neal376's Avatar
normal RWD G35 brakes will fit the AWD model
Old Apr 24, 2007 | 02:57 PM
Woblin_Goblin's Avatar
What about a good set of summer tires? Depending on your climate, keep the all seasons for the winter.
Old Apr 25, 2007 | 03:14 PM
G35m@'s Avatar
sway bars if they make 'em for the X
Old Apr 25, 2007 | 05:42 PM
RichK's Avatar
I have a set of 18" wheels I use in the summer months with 245/40 18" Goodyear F1 GS-D3 tires and my X handles pretty darn good. I am not going to lower it because I don't want uneven tire wear.
Old Apr 25, 2007 | 06:20 PM
yassy's Avatar
put 245 tires on. thats probably the easiest and best solution
Old Apr 25, 2007 | 07:13 PM
Iwantagsedan's Avatar
pardon me fellas...
dont all 05-06n models come with 12.6" front rotor w/twin piston calipers????
Old Apr 25, 2007 | 07:59 PM
aam6906's Avatar
nope x always has smaller brakes
Old Apr 25, 2007 | 09:06 PM
Xman's Avatar
+1 for 245/40/R18
