Brake Fluid Drops
Old Jan 5, 2004 | 10:36 PM
808HerbzG35's Avatar
Brake Fluid Drops
Everyend of the day I always find some brake fluid drops inside my right rear wheel. Has anyone experience this problem? Thanks
Old Jan 5, 2004 | 11:04 PM
Merlin's Avatar
Staff ALUMNI
Re: Brake Fluid Drops
Sounds like a leak, it should not drip at all. Get it checked as soon as possible.
Andrew, We Miss and Love You! Peace!
Old Jan 6, 2004 | 10:21 AM
pestilence's Avatar
^- I agree!
Old Jan 6, 2004 | 03:33 PM
I called Infiniti this morning and they are booked until the 20th. I guess for now I'll just be prepared to use the foot-e-brake. Thanks.
Old Jan 6, 2004 | 04:27 PM
shodog's Avatar
It might be as easy as tightening the brake line fitting or snuging up your bleed valve. It might save you the hassle of going to the dealership for work.
I am surprised that they didn't give this issue top priority. If you were to have a brake related failure and accident, they could be held liable for not addressing your problem
Jim
'03.5 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Jan 7, 2004 | 01:09 AM
Shader7's Avatar
If you are cavitating air into the brake-line from a vacuum caused by losing brake fluid from a low-point leak, it can easily cause catastrophic failure of the braking system. Make sure your dealer knows this, and that you have clearly communicated it to more than one of their representatives.
If you fail to make a stop, resulting in property damage, or worse, personal injury or death as result of this, it would be, uh, . . . bad.
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old Jan 7, 2004 | 01:18 AM
ABQ_G35's Avatar
If it were me, I would just show up there with it, the hell with waiting until the 20th, that does need immediate attention! If they say no, call Infiniti right there on the spot!
Brilliant Silver/Graphite '04 Sedan/5AT
Old Jan 7, 2004 | 02:34 PM
pestilence's Avatar
Id say just go in and see if you can drop your car off for a few hours........ brake fluid leaking = could be bad.
Old Jan 7, 2004 | 08:21 PM
I stop by the Infiniti Service today and showed them where the brake fluid drops is. They said just keep checking the brake fluid level if it goes down the "minimum line" until I see them again on the 20th.
Old Jan 7, 2004 | 08:28 PM
ABQ_G35's Avatar
That's not right, they seem to be blowing it off to easily! Plus, hope you don't get any on any painted areas!
laksjd84
Feb 28, 2026 01:58 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
linedr89
Aug 17, 2015 05:11 PM
mushu
Jul 15, 2015 03:55 PM
