Another Problem :/ not liking the G right now
Old Jun 20, 2007 | 11:22 PM
digital1986's Avatar
Hey guys, I just started noticing this clicking like sound from where my back seats are. I took the back seats and it went even louder. Its hard to explain, I have a video but you can barely hear anything because of the road noise. It seems like the sound is coming from under where the seat would lay.... The clicking like sound only happens when the car is in motion....any ideas.... this car is starting to suck with all the problems!!!
You can barely start to hear the sound towards the end of the video
(Its in .mov format or quicktime sorry but when I converted it lost more quality)
Old Jun 20, 2007 | 11:31 PM
I will see if I can get a better sound clip
Old Jun 20, 2007 | 11:45 PM
G35Papa's Avatar
^I can't hear anything. Sorry
Old Jun 20, 2007 | 11:47 PM
(>")> G35's Avatar
Sounds like the rear axle clicking problem. I think there's a TSB for it.
Old Jun 20, 2007 | 11:54 PM
I searched an searched
do you guys think this is it?
http://www.infinitihelp.com/Ownershi.../ITB05-002.htm
Old Jun 20, 2007 | 11:55 PM
(>")> G35's Avatar
Yup, that's the one I was looking for.
Old Jun 21, 2007 | 12:03 AM
Sweet!!! That shouldnt be too bad to fix then
Old Jun 21, 2007 | 12:39 AM
sd_diver's Avatar
Ironic - my 05 sedan is spending the night at the dealer for this problem. The heard the noise and are trying to diagnose the problem. I'll give them this 1st thing in the morning. They really hate when I do this!
Old Jun 21, 2007 | 02:29 AM
haha ya that should cut some time away from not having your car
Old Jun 21, 2007 | 12:27 PM
jimmyc13's Avatar
I had a creaking/clicking noise issue w/ my car a while ago & ended up diagnosing it/fixing it myself. Sound came directly from behind the rear seats. It turns out the steel diagonal cross bracing behind the seats was loose....several of the nuts weren't even tight!!! Tightened them up & I was good to go.
My sounds were only evident when driving slow, over bumps/uneven roads though.....
Old Jun 21, 2007 | 12:29 PM
thats good to know, mine happens right when I hit the gas pedal and it goes to a faster clicking like noise. I hope that will be a quick fix!
Old Jun 21, 2007 | 12:58 PM
ttrank's Avatar
Grocery getter
That doesn't sound like the axle click. I'm no expert on this subject but from what I know, the axle click is more of a couple clicks when taking off or changing speeds but always at low speed and change of rotational momentum. I believe I am experiencing it right now on mine.
Old Jun 21, 2007 | 07:30 PM
the video doesnt show the sound much. But when I go faster in the car the clicking noise goes faster and faster and a little louder as well. There was so much road noise it didnt pick much up
Old Jun 22, 2007 | 12:45 PM
jimmyc13's Avatar
Well if yours is a direct result of speed, then definitely not the rear support. Maybe you have a rock in your tire!!!!!!
Old Jun 22, 2007 | 01:29 PM
cato's Avatar
SouthernComfort Moderator
That happened to me, only it was an interior nut that had come off the valve stem. There were two nuts on valve stem inside the tire, the outer one came loose and dropped into the wheel. As I drove slow, I heard this clicking that drove me crazy. At higher speeds, the nut was kept against the tire. Took it to the Stealership, and they cahrged me more than $100 to tell me the sound was coming from within the tire.
