Auto shift into 5th
Old Jan 16, 2004 | 10:54 AM
dnapoli's Avatar
Auto shift into 5th
I have an automatic G35X. Well all G35x are automatic...anyway. When it's cold I can't get the car to shift into 5th gear. Once the car has warmed up it will. Does anybody else have this problem?
If it's a G it's 4 me!
Old Jan 16, 2004 | 11:02 AM
ncozby's Avatar
Re: Auto shift into 5th
Are you talking about in full auto or manumatic mode?
Sounds like something you should alert the dealer to, probably needs to be looked at by service. On my old sedan it would run to higher RPM in 4th, I assumed because the car was trying to warm itself up, but I don't think it completely refused to use 5th gear.
<font color=blue>04 DG/G Coupe 5AT - St. Louis, MO
Premium, Aero, Performance, Splash Guards
Metallic Tint - 5-Wire Grounding Kit
MB Quart / Eclipse Stereo
PIAA Extreme Whites - K&N Drop-In</font color=blue><P ID="edit"><FONT class="small"><EM>Edited by ncozby on 01/16/04 08:03 AM.</EM></FONT></P>
Old Jan 16, 2004 | 12:36 PM
SixFive's Avatar
Maybe he is in manu mode and it's stuck on 4 - o wait thats a sedan thing
Old Jan 16, 2004 | 03:46 PM
kb9coupe's Avatar
overdrive button ?
kb9coupe
Old Jan 16, 2004 | 10:00 PM
dnapoli's Avatar
It's in manumatic mode.
2004 G35x
Diamond Graphite~Graphite~Premium~Wood~Splash Guards~7 Wire Grounding Kit~Z-Tube
Old Jan 16, 2004 | 11:26 PM
ABQ_G35's Avatar
overdrive button ?
<hr></blockquote>
What, overdrive button, this isn't a Ford, LOL!
Brilliant Silver/Graphite '04 Sedan/5AT
Old Jan 17, 2004 | 03:04 AM
maximafia's Avatar
What, there's no overdrive? I was thinking the exact same thing kb9, hehe. It's usually the most simple thing that you overlook, and when someone mentions it, you're like "DOH!".
-Max
'03.5 Ivory Pearl 6MT Sedan
'87 Chrysler-bishi Star-Quest 5MT
Old Jan 17, 2004 | 11:47 AM
ABQ_G35's Avatar
When you have it in Drive, it automatically goes into 5th, no switch needed.
Old Jan 18, 2004 | 06:57 PM
Brent's Avatar
This sounds normal for almost any auto trans made today. What it is doing is warming up the trans once it reaches a pre- determined temp it will allow a shift to 5th. It does this to prevent trans damage. Doing this keeps the torque converter unlocked building heat faster. I'm not quite sure of all the reasons but I know that the cold (thick oil) runs at increased pressures and can cause valve body and seal damage unitil it warms up. I live outside of the city and on a cold day it is not uncommon for the trans to shift between 4th and 5th many times when on the hiway. I hope this helps?
Old Jan 18, 2004 | 07:17 PM
Msedanman's Avatar
O.F. Administrator
I'm inclined to agree with 'Brent'. The tranny will not shift into top gear or even lock up until it reaches a certain temp. I believe this prevents damage in a cold tranny, and also promotes heat buildup.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Jan 18, 2004 | 09:40 PM
mbryda's Avatar
Yup - it's normal. Helps the car, transmission, and emissions equipment warm up faster. I think if you go really fast it will eventually lock up, but that's not a good idea with a really cold engine anyway.
Old Jan 18, 2004 | 09:44 PM
zorro's Avatar
That's why I warm my car up, before I even take it out of "Park" position. I think it'll help the engine in the long run.
G35 Coupe. Diamond Graphite, Graphite, Premium and wheel and Tire package. Zaino Baby.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Charchar66
Dec 19, 2019 01:17 PM
dcsbh1
Oct 1, 2015 03:15 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
