Installing clear corners?
Old Jan 24, 2004 | 03:27 AM
tedtf's Avatar
Can someone give me a quick overview on how to do this correctly? I searched forums but could not find info? The pair I have has Japanese language manual.
2003 Brilliant Silver Sedan 6MT
Old Jan 24, 2004 | 04:34 AM
NicNoobie's Avatar
Re: Installing clear corners?
Just pull hard...it should pop right off. Trust me, once you pull, you'll be able to figure the rest out on your own. You might want to try checking your search parameters too, because I'm confident this topic has been covered before. Good luck.
- NICNoobie
2003.0 AT Brilliant Silver Sedan
Premium Package\Graphite Leather\Signaling Clear Corners\AEM Intake (w/ Bypass Valve)
"Why are you my English not being understanding?"
Old Jan 24, 2004 | 12:25 PM
nate's Avatar
I would not suggest to 'just pull hard', although that may work. I suggest you use a screwdriver to push the silver metal tab (found on the back side of the light, inside the wheel well) and pull out 90 degrees away from the fender, then slide it out towards the back of the car. Another tab removes the wire. Putting the new one in is even easier.
2003.5 Sedan Black/Black w/ sport, premium, aero, and winter packages. See my profile for updated mods list and pics.
Old Jan 25, 2004 | 09:42 AM
skeleton_cru's Avatar
Sedan
Please do not "just pull hard". Gain access to the back of the light assembly by removing a few of the plastic fasteners in the wheel well and you may have to remove a phillips screw near the side marker. Once you see the back of the side marker there is a tab you push that should release the light assembly. From there you can disconnect the bulb.
...Skeleton Cru
Old Jan 25, 2004 | 01:31 PM
Shader7's Avatar
It's in the owner's manual as well, in the DIY section. It states to simply pop it off with a screwdriver.
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old Jan 25, 2004 | 09:26 PM
NicNoobie's Avatar
Looks like I may have given out bad advice once again, my bad. Here's an attempt to make ammends:
https://g35driver.com/forums/showfla...view=&sb=&vc=1
It's a possible security mod to prevent theives from ripping off your corners. It states that it's for the coupe, but I'm thinking a similar setup may work for the sedan. Could potentially cause more damage to your bumper tho if the theif is overly persistent. Hope this helps!
- NICNoobie
Old Jan 26, 2004 | 01:42 PM
austinteddy's Avatar
REEEEL easy
Did mine in about the time it took to walk from one side of the G to the other. Screwdriver is a must tho
Old Jan 26, 2004 | 09:12 PM
ncg35's Avatar
Did mine today. It is pretty easy and looks great!
mbe093
Lights
Oct 2, 2016 11:09 PM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
RA081024
Aug 18, 2015 07:03 AM
underworld
Aug 6, 2015 01:36 PM
