G35 Part failures and other problems
I thought I'd start a thread about part failures and other troubles.
Here are mine:
2004 G35X - 74K miles, I had an intermittent problem on long trips with the cruise set to 75 mph. The engine would suddenly loose power (as if I took my foot off the gas) and display Service Engine Soon. If I did press the gas pedel, there was no response. I then would coast to the shoulder, shut-off the car, wait about 5 minutes, and then restart it. It would then act normally. This happend several times for about 6 months. It wasn't until if happend twice in a week that I took it in to the dealer. They said it needed a new throttle body which cost me $458.
76K miles, display of Service Engine Soon light, but no noticable change in engine perfromance. I thought maybe it was the old loose gas cap problem, so I waited a week for it to go away. It didn't, so I took into the dealer again. They reported that the catalytic converter needs to be replaced. They said that they would order one and call me when it is in. They also told me it will be no charge because of the emissions warranty.
Please share your problems and failures, along with the mileage, model and year.
Here are mine:
BCM replaced at 45k miles. I bought the car used and didn't notice it until that night. I still have factory warranty so I wasn't worried. They also did the fuel hose replacement and pro-rated my battery and I only paid half price.
Originally Posted by g35john
THE SEAT TRACK IS JUNK!!! Im on the 3rd one and now that im out of warranty im not looking forward to paying for the 4th out of my own pocket.
-seat was broken; replaced entire bottom half (motor included) warrantied.
-Clutch sensor died, car wouldnt start because it thought the clutch was not engaged. -warranty
-CEL on, gas cap, gas cap, gas cap, then they finally figured out it was a valve that was staying open. warranty.
-front control arms - warranty
other than those, this car has been awesome. no major issues and no money out of my pocket.
Maybe the valve is a problem for me too. Once in a while I can't fill the gas tank past half way. Usually it happens when I run the tank down to the point that the low fuel light comes on.
Originally Posted by ActionAl
I had my drivers seat track replaced after my car was rear-ended. It has always seemed a little loose. What is the issue with yours?
Nearing 51K miles on my '03.5 and I haven't had any major problems.
The most recent problem was the faulty auto-close function of the front passenger window, which I fixed myself by resetting the limit switch inside the door panel.
Originally Posted by filanj
$458 Throttle Body?! You got ripped off! You can pick them up off Ebay for less than $80.
Rattling deck due to sub fixed a few times.
Seat tracks
Fuel hose recall
Had BLOSE head unit replaced 3 times early on
On 3rd tranny, swapped twice under warranty
and of course our famous brakes
Seat tracks
Fuel hose recall
Seat tracks
Fuel hose recall
Seat tracks
Fuel hose recall
