Make it sound like a coupe
Aug 9, 2007 | 03:56 PM
Quote: I am about 99% ready to do the coupe middy swap but could someone be VERY specific about just how much modification needs to be done to make it fit correctly? I mean, in your opinion, do you think that Midas and/or Mieneke will give me much hassle for it or charge me significantly more because of the fitting issues? Thank you for a final answer here!
You really dont need to pay Mieneke to do the coupe mid pipe swap. The coupe midpipe is only 4 bolts and one rubber hanger, complete bolt on, no modification needed. Its easy to get to if you have a lift to work on or a good tall jack at home (not the tiny one that comes with the car). The only issue you may run into are rusted bolts. If you think ahead and grab some PBblaster (or another kind of rust penetrant) and spray the bolts before you begin you should be fine. Add HP? Maybe a few (>5) but the weight savings and sound alone are worth it.
Take a look at This Thread for my pics and review on the Coupe middy and Z tube/pop charger:
https://g35driver.com/forums/g35-sedan-v35-2003-06/169067-coupe-mid-pipe-z-tube-pop-charger-review-pic.html
Reply 0
Aug 9, 2007 | 04:00 PM
The coupe midpipe was too short for my car. I had an extender made to bolt on in between the y pipe and the midpipe to make everything fit.
Reply 0
Aug 9, 2007 | 04:35 PM
Quote: The coupe midpipe was too short for my car. I had an extender made to bolt on in between the y pipe and the midpipe to make everything fit.
I have not heard anyone else with that problem, strange.
Reply 0
Aug 9, 2007 | 04:42 PM
ok seriously,....and i know you guys wont believe me...but i seriously think my new exhaust setup sounds the closest to the coupe.....i didnt think it would..but holy crap its almost the same...i have stainless steel headers..megan racing ownpipes, megan racing y-pipe and a greddy evo 2 exhaust dude...almost just like it when i step on it...ill post a sound clip if i can soon
Reply 0
Aug 9, 2007 | 04:56 PM
Sounds like it was a 350z midpipe.
Reply 0
Aug 9, 2007 | 05:01 PM
Quote: Sounds like it was a 350z midpipe.
+1 also the coupe midpipe is easy to install as long as you don't strip a the bolt other than that its a breeze
Reply 0
Aug 9, 2007 | 06:53 PM
I hate doing exhaust work HATE IT!!
it makes you black and blue and red all over mostly b/c most of us dont have lifts and must perform such work on our backs.
than when something doesnt fit...for god knows what reason - you have to go running for drill bits
than you lower the car - start it up and and figure that you either forgot a gasket or a bolt and you must do the whole process over.
i had an exhaust leak the other week and was contemplated lifting the car - removing the stripped bolt and applying exhaust gasket
instead - I went to an exhaust shop - car was placed on the lift for 5 minutes...bolt removed, gasket installed ===6 bux
DONE...and i did that all with slacks and a white collar shirt
Reply 0
Aug 9, 2007 | 06:57 PM
oh yea
anyways
you will never EVER get the burble of the coupe unless you have an exhaust shop install the coupe rear muffler on your sedan
I have the fast intentions H/f Cats. Im not a coupe but everywhere I go I always get "this sh$# sounds sweeet" im very happy with this setup. I have stock cat back too!
Reply 0
Aug 9, 2007 | 07:04 PM
Quote: +1 also the coupe midpipe is easy to install as long as you don't strip a the bolt other than that its a breeze
+1 I tried to put a Z pipe on as well, too short. Coupe midpipe bolted right up. Now I wish I would have taken pics of the Z pipe next to the Coupe. Oh well
Reply 0
Aug 10, 2007 | 07:04 AM
350Z mid-pipe is too short. The Coupe mid-pipe fits perfectly on the sedan.
Reply 0
Aug 10, 2007 | 09:41 AM
put twin turbo with open watsegate dumps on your sedan. Then people won't say that it sounds like coupe.....instead, they'll say "Dayyyyyummmmmmm!!!!"
Reply 0
Aug 10, 2007 | 11:11 AM
or get this bad boy!!!
http://cgi.ebay.com/ebaymotors/BLOW-...spagenameZWDVW
sickest mod you can get for the G!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11111111oneoneon e
Reply 0
Aug 11, 2007 | 09:02 PM
Has anyone tried this? Is it too loud? I guess it would restrict the exhaust.....say what?
Reply 0
Aug 11, 2007 | 10:49 PM
I have the coupe middy, HKS rear. After I added a Popcharger, I noticed the exhaust note change a bit...sound more "like" the coupe but still not the coupe. Love the sound either way.
Reply 0
Aug 11, 2007 | 11:08 PM
  #30
I have the Greddy Evo 2 catback. After about 2 months the resonator started to rattle. It got to the point that I was getting sour looks from the gate gaurds. So I went to an exhaust shop and they replace the resonator with just a strait pipe. Yea they had to weld on my new Greddy but that only costed me 30 dollars. IMO my exhaust sounds just like the coupes. My buddy says that it sounds more like a Carrera. (sorry for spelling) If you want to hear it I will make a video.
Reply 0
