Fiberglassin some boxes. A first for me.
Old Sep 4, 2007 | 11:18 PM
psedog's Avatar
Back in SD**
Thanks TT,
I'm getting better at the bondo, but still getting bubbles. Not sure why, anyone now how to weed them out?
Old Sep 4, 2007 | 11:36 PM
JOKER's Avatar
CLUB MODERATOR
that's going to be one heavy box.
I'm not a pro or anything I have not worked on sub boxes before but I know a fiberglass like a back of my hand. I have worked with it for loooooooooooong time.
I think you should have used a material to wrap the box and then spread the fiber glass on it. that way you would have kept a nicer shape to the box and used less bondo.
But still looks great.
Props for great work
Old Sep 4, 2007 | 11:42 PM
psedog's Avatar
Back in SD**
I did, but I tried to use something (like a thin foam) on the inside of the fabric to stabilize the shape and it ended up crumpling. That's why I have those ripples. So, when I do the other side I won't use that crap.
Edit: the box is still pretty light (at least without the sub in it )
At first I wasn't going to use wood as the bottom base (to save weight), but then I started to worry about it being top heavy.
Old Sep 5, 2007 | 08:16 AM
QuadCam's Avatar
[QUOTE=psedog]Thanks TT,
I like rage gold better than bondo. it sands much better.
Are you going for a painted finish? or are you carpeting/vinyling the exterior? normally, you wouldn't want to use that much bondo.....especially if you are doing it for strenghth.
Old Sep 5, 2007 | 09:13 AM
Hi-TechG35's Avatar
Looking good.
Old Sep 5, 2007 | 01:17 PM
jimmyc13's Avatar
Nice work! It's the G35driver.com version of Pimp My Ride!
Old Sep 6, 2007 | 01:35 AM
psedog's Avatar
Back in SD**
Current state.
Primed and tested. Sounds pretty good. Looks like I achieved my goal of tuning to 35hz. Now I need to find a bolt that will hold this in place. Also need to get some carpet and some carpet adhesive spray. Soon I'll start on the other side.
Edit: I also have a few air leaks through the sub hole and terminal block hole. Anyone have any tips on how to fix this, or will the carpet be good?
Old Sep 6, 2007 | 09:08 PM
BXG35x's Avatar
hey, what program did u use to design your box? I wanted to do fiberglass to but i need to put my sub in a ported box with the correct volume.
Old Sep 6, 2007 | 09:16 PM
psedog's Avatar
Back in SD**
No program, just measured. I got the cubic feet to port length x port size off of a web page. When I get to my other computer, I'll post the link.
Old Sep 6, 2007 | 09:29 PM
psedog's Avatar
Back in SD**
Here is the website that I was able to calculate the port length. They have all kinds of calculators on that page.
http://www.the12volt.com/caraudio/boxcalcs.asp
Old Sep 6, 2007 | 09:31 PM
digital1986's Avatar
Very nice!!!!!!!!!!
Old Sep 6, 2007 | 09:53 PM
hai109's Avatar
Very nice...You coming to the BBQ in OC? I want to hear it...
Old Sep 6, 2007 | 10:15 PM
MrPutzy's Avatar
Nice work. Is that regular old blue painters tape? Also, did you stick the tape directly to the carpeted trunk liner panel?
I have been considering a spare tire well sub enclosure out of fiberglass. I did one a long time ago, but used plastic sheeting as a bond breaker. Worked OK but was a pain in the behind as it never stayed where you wanted it.
Thanks for the pics.
Old Sep 7, 2007 | 01:53 AM
psedog's Avatar
Back in SD**
MrPutzy,
Yup, regular painters tape. I laid 2 layers and then used some liquid carnuba wax on top of the tape, just in case.
Hai,
Most likely. It is in OCT, right?
Old Sep 7, 2007 | 11:03 PM
  #30
MrPutzy's Avatar
Cool, thanks.
