Fiberglassin some boxes. A first for me.
Hey psedog looks great but is that port hole aleast 4 inches from you trunk lid? Your sending all the air directly to your trunk lid might cause alot of vibration. Are you gonna wrap it or get it painted?
Originally Posted by psedog
Edit: I also have a few air leaks through the sub hole and terminal block hole. Anyone have any tips on how to fix this, or will the carpet be good?
Originally Posted by GixxerSteve
My guess, either rubber weatherstripping around the holes, or silicone.
I'll probably pick up some silicone next week.
I haven't started on the driver side yet. I had to send one of my subs back to the manufacturer, so I haven't been in a big hurry to do that side. I've been looking for carpet, but I haven't been able to find anything that looks like our carpet. I read somewhere that someone used black carpet and sprayed a light mist of gray on it, to get it to look right. I think I'll give that a shot.
The box is mounted, but it looks pretty much the same as when you saw it two weeks ago at the meet.
For the Drivers side I'm trying something different. I'm using expanding foam to try and make a mold.
I used regular masking tape on the carpet and now that I have pulled it out. I am going to use blue painters tape and use something on that side as the actual mold. Do you guys think that I should use foam again, or Bondo?
That was 2 cans of foam.
So about 11 bucks. When I do the inverse side it'll be about 22ish. Definately better than laying several layers of glass while crunched up in the car. Plus the smell that the resin leaves behind.
Here I used bondo on the back of the foam and then I foamed behind the bondo to give it strength.
I have now removed the inner (original) foam and this is what I'm left with.
Yes the foam still looks like a brain or as someone else said, barf.
And here is all the foam that was removed from the inside and it was a pain in the ***.
