Thermostat & overheating issue
Old Sep 7, 2007 | 07:49 PM
SE2002's Avatar
Does any body know where the thermostat is located at? any pictures and instructions on how to replace it?
My issue: My car last week with 100-110 temp in socal my car started to throw out warm air and my temp in the car started to rise. It never overheated because i would turn off the A/C and the temp would drop back to normal. The warm air issue was on/off sometimes previous to that....sometimes it would get warm..then kick in again to cold....then again warm later on and back to cold. Any suggestions on what can be the issue? I'm going to get radiator flush this week...but should i replace the thermostat while i am at it?
Thanks my peoples.
Old Sep 7, 2007 | 11:51 PM
sliderg35's Avatar
Is this what you're looking for?
Old Sep 8, 2007 | 12:39 AM
junbug's Avatar
Check your coolant level as well. Sounds like you could use a flush too.
Old Jul 8, 2008 | 03:33 PM
SE2002's Avatar
My car has 141,000 miles on it. 2003 Sedan
Im having this similar issue again. My cars temp is reaching way to high...close to overheating 75% high. This only happens when the A/C is on and i am in a stop and go traffic, idling for a while or on the regular road. On the freeway is ok and fine. My A/C starts to get warm and muggy and the temp rises. When i turn off the A/C my temp gauge goes back to normal. This happened before and I did a radiator flush and replaced the thermostat. It worked fine afterwards. Could this had happened again because of the heat here in socal..freakin 108+ lolz?? My mechanic said the thermostat was bad before..did the thermostat go out again?? or could it be something else? How can i check?
Old Jul 8, 2008 | 04:03 PM
Klubbheads's Avatar
do the flush first and then worry about the thermostat. With 140k on the car the previous owner(s) might have never changed the coolant on the car therefore causing the car not to cool efficiently.
Old Jul 9, 2008 | 01:35 AM
DaveB's Avatar
Make sure you have no air bubbles in the coolant passages. There is a very detailed procedure to getting out air bubbles when removing/replacing coolant. Just a couple bubbles could cause cooling problems.
Old Jul 9, 2008 | 07:34 AM
Neal376's Avatar
take your old thermostat and boil it in a pot of tap water in the kitchen to see if it still works. if its broken - then you prob had solved your problem
if it isnt broken - then i would imagine that the electrical connection to your aux fan is broken
coolant forms a gunk after it has been left in a vehicle for too long - it then accumalates on various components - rotting away things as important as your water pump
Old Jul 10, 2008 | 10:59 AM
SE2002's Avatar
aux fan? where is that? Cuz the radiator fan turn on....and like i said...did a radiator flush and thermostat replacement last year from what i see my post.
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
NohoG35revup
Aug 22, 2015 12:13 PM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
Smittie20
Aug 9, 2015 04:29 PM
joedaddy1
Jul 28, 2015 02:58 PM
