Removing Infiniti letters
Old Sep 24, 2007 | 09:17 PM
snavematt's Avatar
just a sedan
I looked for this but did not see it, want to remove the Infiniti letters off the trunk. Are these just glued or are the on a different way?
Is there any glue to remove. This is an 03.5 (no doggy door)
Thanks
Old Sep 24, 2007 | 09:22 PM
j 4 lD's Avatar
search 'debadge' in the forum. This is the process of removing these letters.
they are glued on and can be easily removed but beware, since your car is 4 years old, the letters might leave an outline on your car since the paint around them has faded.
j 4 lD's Avatar
Old Sep 24, 2007 | 09:26 PM
j 4 lD's Avatar
wow, sorry, that was a mistake. I repeatedly clicked it and it wasn't working. Guess it was just a little slow.
Old Sep 24, 2007 | 09:43 PM
snavematt's Avatar
just a sedan
thanks, now I feel like a tool, hey Im new, thats my excuse. Thanks
Old Sep 24, 2007 | 09:47 PM
j 4 lD's Avatar
tool?
Old Sep 24, 2007 | 09:49 PM
snavematt's Avatar
just a sedan
tool=dork
Old Sep 24, 2007 | 10:05 PM
lexusk8's Avatar
Fishing line (can be obtained from Walmart) is all you need to slice the badges from the trunk lid. After that use either your fingernail or a plastic tool to remove the adhesive from the trunk lid. For me when I debadged my Lexus (previous car) I use the plastic spatula that comes with my George Foreman cooking grill Then afterwards you can further remove the adhesive with some 3M rubber compound polish, use Meguiar's Scratch-X if necessary to remove any fine surface scratches, and finish it off with a final polish and wax.
Old Sep 24, 2007 | 10:41 PM
O HELLA OEM's Avatar
and to get that excess adhesive off your trunk use GOO GONE..IT WORKS REALLI GOOD..u can buy it at autozone or pepboys..
Old Sep 25, 2007 | 10:47 AM
68_GT's Avatar
used my fingernail and was able to pull off all the lettering except the "N's"
Old Sep 25, 2007 | 03:54 PM
jaydafunk's Avatar
when i did mine, i heated the glue up with a hair dryer and dental floss. they came right off. then i used my fingernail to take the rest off. then cleaned it and waxed it.
Old Sep 25, 2007 | 05:13 PM
G'd Out's Avatar
I removed my Infiniti and G35 on mine. I heated half of it and used floss on it. The other half I just my fingers. Between the both, the heating did nothing extra. The floss will cut it slightly closer to the body, but not much. Then I used Goo Gone and used my fingers to take care of the rest.
Old Sep 26, 2007 | 03:22 PM
Platinum Sedan's Avatar
Dental floss is def the way to do. If you live in a warm climate, you don't even need a heat gun/hair dryer.
Old Oct 2, 2007 | 11:39 PM
sixthGear's Avatar
i def DID NOT do ANY of the above, straight went at it with a plastic utensil, it was a disaster, there was glue residue everywhere and while i searched for ways to clean it off, it was pretty much set on... took A LOT of work to get it of, so if anyones thinking about it, def read the debadge thread on here!!
Old Oct 2, 2007 | 11:50 PM
Beebo's Avatar
DO NOT use Fishing line...
tiguy99
Mar 1, 2016 11:42 AM
Frostbite91
Jul 27, 2015 05:25 AM
