Quick Question on Spacers
Old Oct 10, 2007 | 11:10 AM
CLyons0203's Avatar
So I have decided my next mod is gonna be a plenum spacer. Looks like MD makes them the best.
Why do you sedan guys go for the 5/16 more often then the 1/2? I did a search and seems like the 5/16 gives more mid range and the 1/2 gives more top end. Both fit under the factory engine cover on the sedan.
I do see that the 1/2 give alot more engine induction growl sound. Is that true?? sound clips?
Which do you guys think is best 4 a 05 Sedan auto.
Old Oct 10, 2007 | 11:39 AM
WILLIE BEANS's Avatar
good info to know ..
anyone have an opinion .??.??
Old Oct 10, 2007 | 01:47 PM
jimmykce1's Avatar
I have a 06 sedan and will be getting the 5/16 spacer, which fits under the stock engine cover. Although I took my stock engine cover off and installed a Richie's STB.
I believe the 1/2 spacer will not work under the stock engine cover. I have been told by a preformance shop the 1/2" only gives you 1 to 2 more ponies at the top end over the 5/16 spacer.
Old Oct 10, 2007 | 03:15 PM
ttrank's Avatar
Grocery getter
I have heard that the 1/2" can rub on the hood insulation.
Old Oct 10, 2007 | 11:15 PM
CLyons0203's Avatar
so is it true the 1/2 spacers rubs and will make the engine alot louder?
Old Oct 11, 2007 | 12:30 AM
G35Papa's Avatar
The consensus you will find on the boards and in your research is to go with the 5/16 spacer.
Old Oct 11, 2007 | 01:01 AM
HUMBOLDT_G's Avatar
IMO in a street car it would make more sense to go with the 5/16 spacer if it does in fact give you more "useable" midrange power. If you were building a race car then I would go with the tallest one available.
Old Oct 11, 2007 | 01:49 AM
Beebo's Avatar
5/16 Ftmfw
Old Oct 11, 2007 | 02:05 AM
ttrank's Avatar
Grocery getter
Originally Posted by Beebo
5/16 Ftmfw
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
