DIY Video Series
Old Apr 15, 2009 | 08:16 PM
  #226
seymore4's Avatar
m56
This is an awesome thread... WHY DID I JUST NOW FIND THIS!!?
LOL
Thanks man
Old Apr 15, 2009 | 09:57 PM
  #227
OCG35's Avatar
LOL
Thanks man
becasue you had only been here a month or less when you posted this
Old Apr 16, 2009 | 11:19 AM
  #228
MidnightG35X's Avatar
Anything ever happen with making DVD's out of this?
Old Apr 16, 2009 | 01:03 PM
  #229
jimNC's Avatar
Still waiting on a valve cover DIY
Old May 10, 2009 | 12:47 AM
  #230
bythabay's Avatar
Hmm.. maybe if there is enough demand So far I am too busy working on people's cars
Old May 10, 2009 | 12:48 AM
  #231
bythabay's Avatar
Hey, as soon as I need to do the work, consider the DIY completed - the valve cover repair is one I am looking forward to.
Old May 10, 2009 | 12:49 AM
  #232
bythabay's Avatar
Front strut (shock & spring) replacement (Eibach Pro Kit)
Old May 11, 2009 | 10:15 PM
  #233
bythabay's Avatar
Clutch Fluid Flush/Bleeding
Old May 12, 2009 | 10:36 AM
  #234
I bet you could find a healthy number on this site alone
Old May 12, 2009 | 12:12 PM
  #235
bythabay's Avatar
I think they should be the ones finding me; I would think it is quite easy to contact me
Old May 12, 2009 | 12:16 PM
  #236
I guess I'll be the first to raise my hand saying I want it! Even if you just have the raw video files, I'd take it!
Old May 12, 2009 | 07:28 PM
  #237
jimNC's Avatar
I probably won't be able to wait long enough for the DIY video, but the plenum spacer install should be pretty much all I need as the valve covers are right there after the upper/lower plenum is off.
Do you know what gaskets besides the obvious valve cover gaskets should be replaced at the same time, if any?
Old May 13, 2009 | 02:04 PM
  #238
bert039's Avatar
^According to the service manual, you're supposed to replace these three gaskets when you remove the plenum.
You don't really need to remove the throttle body from the upper plenum unless you're going to take it apart and clean it. So you might not need the throttle body gasket.
On the valve covers, aside from the two valve cover gaskets that you already mentioned, if you're changing the passenger side valve cover you will only need to replace the O-Ring that's under the PCV valve.
Old May 13, 2009 | 02:45 PM
  #239
bert039's Avatar
I'm actually doing the valve cover gaskets this weekend. I'll let you know if I run into any specific issues.
Old May 13, 2009 | 03:40 PM
  #240
jimNC's Avatar
Thanks Bert. I had thought of the intake gasket but I did not consider the O-ring on the PCV valve. The valve covers are expensive - did you find a good source? Best I could find was infinitipartsonline and infinitipartsusa which sell the pair for ~$365. With gaskets and shipping the total approaches $500. Ouch.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
