Battery + Brake (!) leds ON
Old Dec 11, 2007 | 11:25 PM
Gilley's Avatar
Wherever you take it, don't take it to the dealer to be repaired. That will be the most expensive option.
Old Dec 12, 2007 | 09:24 PM
kwiniarz's Avatar
going to a buddies of mine tomorrow, i'll keep you guys posted.
Old Dec 14, 2007 | 11:43 PM
kwiniarz's Avatar
Well after starting it on Thursday the light was gone, I had my mechanic check and he could see nothing wrong. He thinks it might have been a loose belt?
Old Apr 22, 2008 | 06:53 PM
knahledge's Avatar
I'm actually having the same issue. They come off and on. I noticed when it comes on my daytime running lights start to flicker and i can hear a slight buzzing sound. the headlights still shine bright though and all the accesories are running fine. Any ideas?
Old Apr 25, 2008 | 12:19 AM
streetxtreme's Avatar
i just had the same issue after starting the car with one wheel jacked up
i was just checking for an oil leak .
the light came on suddenly, i dropped the car back down, and when for a drive...
about 5 minutes later, the 2 lights went away.
i check the voltage while the lights were on, and the voltage was around 13.8-13.9v
when the 2 lights were on, they were both very dim
alot more dim that if you had the engine off with the key in the "on" position.
Old Apr 25, 2008 | 12:28 AM
i'd like to know what this is if anyone every finds out
Old Feb 13, 2009 | 09:14 AM
kwiniarz's Avatar
Damn! my original problem with the battery and brake light is back, it's been almost two years since i've seen this.
I let the car sit for 2 days, there was some real heavy rain but now it's just below freezing point.
Battery is fine and alt is fine i get 14.6 when the car is on and 12v when off.
any ideas?
Old Feb 15, 2009 | 04:26 PM
kwiniarz's Avatar
well the brake and battery light is gone again, but now my day time running lights are flickering. I hate electrical gremlins, i must just remove the DRL module
Old Jun 30, 2015 | 11:11 AM
35 SWOOP's Avatar
i have the EXACT same problem right now, 5 months ago my brake and battery LEDS were on, when this happens to the Gs Ive read its a charging system problem, I changed the battery and Alt and it was fixed, just yesterday the lights reappeared, now I have a DIODE issue, they say check ALL connections make sure no corrosion or loose wiring. If wiring checks out, new Alt it is..
Old Nov 9, 2015 | 08:27 PM
Pamela G.'s Avatar
Battery and break lights (!)
Hi, my battery and brake lights are on initial they would go on and off then they would dim but now they are on constantly. I was wondering if anyone had similar problems and what you think it could possibly be. I've change the battery and alternator but the lights still remain on.
jilljann1
Jul 21, 2020 08:12 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
twentyeggs
Sep 11, 2015 03:58 PM
Hawk196
Sep 10, 2015 10:37 AM
NJ6MT
Sep 10, 2015 08:40 AM
