Cobb AccessPort for Early Type I sedans (please don't move this!)
Old Nov 14, 2009 | 09:27 PM
  #61
bbs350z's Avatar
Originally Posted by Jeff92se
Technosquare is in Ca. Yes you have to send it in unless you can drive there.
And yes, early G35 sedans have the light grey ecu connector. UTEC doesn't have a plug and play connector for it. Neither does Emanage, Greddy etc etc etc. UpRev can't reflash the early ecus either.
Now you can hardwire to use the aftermarket ecus like UTEC but that's an involved and complicated process
guess ill have to peek at that n see what i got. but mine has no doggy door but is an 03...**** lol
Old Nov 14, 2009 | 09:53 PM
  #62
Jeff92se's Avatar
Red Card Crew
Then there is a good chance that you are the newer type. But that doesn't mean you can't sign up if you want to get in this deal. Even if you get an UTEC/Emanage etc.. you can't alter the things that are included in the L-spec and F-specs. Like the 100% TB opening, the e-pedal curve etc. Alot of the FI guys get a L-spec to get the rev limits and TB stuff done before tuning with utec.
Old Nov 16, 2009 | 05:09 PM
  #63
Jeff92se's Avatar
Red Card Crew
Update. MPG has climbed back to where it was before the flash! For me that's about 19.x or low 20.x mixed driving. My current tank might be even better. Will advise. But more important info.
The ecu's differences are still very apparent. The low end pull is great along with the improved mid/high end pull. But getting rid of the annoying just off idle lag was the most important part.
As you know Technosquare had their dyno day Oct 18th and had special pricing for their L-spec and F-spec flashes:
An associate of mine that works with TS said he would be willing to ask TS to extend their dyno day pricing to about 5 members that are interested. I'll start the list:
1) Dave B
2)
3)
4)
5)
I'll take the list and see if TS would honor their pricing.
I'm posting this here as the early sedan guys have no reflash options except TS. If the 5 spots can't be filled by interested sedan guys (early or late), I'll post again in the tuner section.
TS info:
dyno day(shows pricing), ecu removal and ecu fill out sheet
http://www.technosquareinc.com/index.html
General ecu and faq informtion here:
http://www.technosquareinc.com/nissanflash.htm
Bump
Old Nov 23, 2009 | 06:12 PM
  #64
Jeff92se's Avatar
Red Card Crew
If the early guys aren't interested, I'll put it up in the sedan section, then the tuner section if the sedan guys don't want to get in on this.
Old Nov 24, 2009 | 12:23 PM
  #65
DaveB's Avatar
So many early 03 owners complain about the lack of an ECU upgrade and when you provide it, they don't respond. Sad.
Old Nov 24, 2009 | 01:10 PM
  #66
Jeff92se's Avatar
Red Card Crew
Probably because it's buried in a non-existant Cobb tuning option thread. I'll bring it up as a new thread shortly
Old Nov 24, 2009 | 02:43 PM
  #67
Swivel's Avatar
Moderator
Interested but broke.
Old Jan 31, 2010 | 09:58 AM
  #68
str3zz's Avatar
I noticed this thread is old but Dave can you tell me or correct me if I'm wrong. I looked at the door sticker and it shown Date 05/03 does this mean may of 2003??
Old Jan 31, 2010 | 12:40 PM
  #69
Tollboothwilley's Avatar
yes. early 2003's are 06/02 - 11/02. You have a "2003.5" version
Old Jan 31, 2010 | 01:39 PM
  #70
str3zz's Avatar
Will this be supported by cobb accessport?
Old Jan 31, 2010 | 06:28 PM
  #71
not likely...why? unless you can get one for cheap the Osiris tune is WAY better.
Old Jan 31, 2010 | 08:28 PM
  #72
NFSP G35's Avatar
? = 2B || !2B
Same kind of problem here.
I think what's going to continue happening is that there won't be enough 03.0 guys that all have money and the mods they want done at the same time as each other.
Why can't Osiris just support our cars too?
Old Feb 7, 2010 | 04:21 PM
  #73
MM_G3520's Avatar
What if I have an 02/02 build date...............
Old Feb 7, 2010 | 05:21 PM
  #74
NFSP G35's Avatar
? = 2B || !2B
^I have a 02/02 build date as well! (What's the oldest?)
Old Jul 9, 2010 | 03:42 PM
  #75
MM_G3520's Avatar
Hahaha, we might be it!
Relic status ITT
