3 panel lights on: Slip, ABS and VDC
Old Mar 19, 2004 | 10:52 PM
Xattica's Avatar
Hi,
While im driving (70mph) 3 lights appears on at the same time: Slip, ABS and VDC. What you think is the problem? When I went to my house and shut down the car, the 3 lights do not get on.
Thanks,
Xat
Old Mar 20, 2004 | 01:38 PM
Msedanman's Avatar
O.F. Administrator
Re: 3 panel lights on: Slip, ABS and VDC
Check out this thread bro. It sounds like the same issue.
G/L
https://g35driver.com/forums/showfla...sed&sb=5&part=
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Mar 21, 2004 | 08:06 PM
Xattica's Avatar
Yeah... Same issue
What would be the problem? Did you know. I will try to ask at the dealer.
Thanks,
Xat
Old Mar 21, 2004 | 08:43 PM
mountain's Avatar
I just had that fixed on my ride....the brake sensor went bad. 10 min. fix under warranty!
Old Mar 22, 2004 | 10:04 PM
ryoken's Avatar
I had the brake (not ABS), Slip, and VDC Off lights come on the other day. Then the brake light went back out, and it was just Slip and VDC Off. When I got where I was going, did my business, got back in the car and turned it on, the Slip and VDC Off lights decided they weren't done yet and came back on.. and again for the start after that. Third restart after the initial indicators, they stopped coming on. I'm not cancelling my appt. to have it looked at tomorrow, though. It's brakes after all.. I'd rather take it in and have them do nothing than have them fail next week. [img]/w3timages/icons/tongue.gif[/img]
Old Mar 22, 2004 | 10:58 PM
johnzg35's Avatar
I had this problem some time after replacing the brake light switch. Took it in and was told it was due to low brake fluid level. You should check this before taking it in for service.
Old Mar 23, 2004 | 03:20 AM
ryoken's Avatar
I have checked the level. Sorry, forgot to mention that. Halfway between the min and max bars. Plenty of fluid. (I've also had the Nav screen pop up "low brake fluid" a couple times during hard braking.. then go away before the car stops completely. This was before the lights on the dash.)
The dash lights didn't come on during braking though. Oh well.. appt. is in the morning. We'll see what they say about it.
Old Mar 23, 2004 | 11:55 AM
ryoken's Avatar
Dropped off the car. The service advisor is guessing I may need new brakes. They've seen the VDC Off/Slip light thing come on as a direct result of the "low brake fluid" warning, as well.
Loaner keychain had an "I30" tag. Great, I though.. oh well. Turns out, though, they simply had a surplus of I30 tags in their inventory and used them for all the loaners. I'm in a red FX35 today. *whoopee!*
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
.cakestar
Engine - Intake/Fuel
Aug 25, 2015 03:17 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
