X front camber kit
Old Apr 10, 2008 | 12:30 PM
jibnasty's Avatar
X front camber kit
Is there a front camber kit out there that works for the g35x?
Old Apr 10, 2008 | 02:36 PM
seddon's Avatar
NO, no front camber kit, no front aftermarket shocks or coilovers.
Old Apr 10, 2008 | 02:51 PM
ttrank's Avatar
Grocery getter
That's what I thought too. Sucks.
Old Apr 10, 2008 | 03:11 PM
FlyingLumpia's Avatar
I remember Neal was successful on putting on SPC (i think) on.
Old Apr 11, 2008 | 05:46 AM
rayron's Avatar
they look like they should fit looking at the pictures.... if it's just the upper a-arm. you should pm one of the infiniti guys and see if the OEM upper a-arm for the awd and rwd have the same part#.
Old Apr 11, 2008 | 07:24 AM
JMAN44544's Avatar
Just me wondering, why do you need it? The guy who did my alignment said he got it pretty darn close with out a kit. I needed the rear for sure.
Old Apr 11, 2008 | 09:20 AM
seddon's Avatar
If you you have a good alignment guy he should be able to get the front close to or in spec. I like the camber in the rear makes the car look really aggressive. My rear is -2 camber.
Old Apr 11, 2008 | 09:23 AM
You are also running a 10 inch wheel. What about the guys without that. We either have to run no chamber to make them more flushed or put spacers on like me. I actually might have to dial in alittle neg chamber for my rears. I think I heard them rub yesterday. But that is what I get for putting a 15mm spacer on a +40 offset.
Edit found Neal post:
https://g35driver.com/forums/g35-sedan-v35-2003-06/155262-spc-arm-install-g35x-first-attempt.html
Old Apr 11, 2008 | 01:40 PM
jibnasty's Avatar
So your H&R springs lowered around 1.5"? and your near spec?
I have the h techs. So im around 1.3" drop in the front. But they are super soft, so my last set of tires wore through the inside tread in around 7k...
Old Apr 11, 2008 | 01:54 PM
JMAN44544's Avatar
Yes. H&R says they lower 1.3 and 1.2, but is easier to say 1.5 fingers gap in the front and 1 in the back. I have the SPC rear camber kit and after the alignment, it is perfect in the rear (.0014 off) and I was told it was darn near perfect on the fronts. I have no rubbing issues. Stock shocks (30k miles) not bouncy at all. I only have about 1500 miles on it, so I cannot really tell if there are any wear issues, but do not foresee any.
jsimonk
Dec 22, 2023 03:49 PM
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
nascarbuff17
Jul 16, 2015 10:23 AM
djreinx
Jul 13, 2015 05:04 PM
