Need Help Painting
Old May 2, 2008 | 07:11 PM
leeroydstroy's Avatar
Need Help Painting
For 2003 g35 sedans, has any one ever painted the black bottom part the same as the car color? I don't know the technical term for that area, I want to say bottom moldings but I think that's incorrect. If any one has ever painted that part, could you provide pics? Or is this a bad idea? I'm thinking about doing this instead of buying a kit (depending on ppl's opinions). Any help would be much appreciated! Thx.
Old May 2, 2008 | 07:49 PM
k@osx71's Avatar
Here's a link to an awesome DIY by DaveB https://g35driver.com/forums/showthr...painting+sills
Old May 2, 2008 | 08:50 PM
heftylefty58's Avatar
Also, from ttrank's sticky:
Q - Can I paint my dark gray side sills on my 03/04 sedan?
The best option is to replace them with the Nismo (Aero) sides. But, they can be painted. Some paint shops will say no and others say yes. With the proper prep and right paint/flex agent/clear they can be painted to match. Many members have done it.
Based on my research, it sounds like the body shops around us charge ~$400+ to paint the side and rear sills. A couple shops actually quoted me ~$800-$1000! I'm still on the fence about getting them painted vs just going with the Nismo sides/rear.
BTW, I think most people on this board call these things "side/rear sills" or "side/rear skirts." The service manual refers to the side sills as "center and rear mud guards." Not sure what the manual calls the dark gray part under the bumper.
Old May 2, 2008 | 10:33 PM
thx...this really helps me alot. I thought I was the only one thinking this...I actually checked out a nearby shop and said that they can do this for me for 500. If you guys can post up some before and after shots, that would be much appreciated!
Old May 2, 2008 | 10:56 PM
DaveB's Avatar
My before and afters are in my DIY. The process is really quite simple. The hardest part is all the prep work. The paint has adhered flawlessly.
Old May 3, 2008 | 01:48 AM
yea i saw it, it looks really good. Was that the same paint as the car color code for your g?
Old May 3, 2008 | 01:53 AM
OCG35's Avatar
the after isn’t very good... in fact it's to show other things on the car, but it should give you an idea... if you search around you'll find lots of car that have done it and there are a bunch of pics around... good luck, show us yours when your done
Old May 3, 2008 | 12:15 PM
DaveB's Avatar
Yep. I went to the auto paint store and got the Nissan factory black made by PPG.
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
9tray turbo
Sep 29, 2015 10:22 PM
