Is the coupe mid pipe the choice for a sedan?
Old May 5, 2008 | 12:51 AM
Kazaam's Avatar
[QUOTE=stillmatic]There's no benefit from switching to a Coupe midpipe if you have an 05-06 Sedan. They're pretty much the same. You should look into an axleback exhaust if you're going for sound.
[quote]
No they're not the same. BIG difference in both size and SOUND!!!
Old May 5, 2008 | 10:30 AM
TCD's Avatar
TCD
Hey DaveB,
Thanks for the videos. That's exactly what I needed to hear. Great mph in the 1/4. What was you 60" time on the 14.32 run?
Todd
Old May 5, 2008 | 12:01 PM
Swivel's Avatar
Moderator
Originally Posted by DaveB
Here's my 03 sedan with an 06 sedan midpipe taking off with 30% throttle and then full throttle.
Just to be clear - 06 sedan midpipe? I also have on 03 sedan (long live the doggy door) and it definitely has a bit of growl with the smaller stock muffler than later models. I wouldn't mind trying out a coupe middie just to hear if there's much difference. I expect it would certainly be detectable.
Old May 5, 2008 | 12:27 PM
DaveB's Avatar
Originally Posted by TCD
Hey DaveB,
Todd
2.15 if I remember correctly. The car usually sees 2.15-2.18 60 foots.
Old May 5, 2008 | 12:33 PM
DaveB's Avatar
Yep, the 05/06 sedan midpipe. The advantages are this:
1) significantly smaller resonator
2) complete bolt-in with no need to bend heat shields like you do with the coupe midpipe
3) the resonator is designed to match the design of the sedan muffler (variable flow, straight flow) noise characteristics vs that of the coupe which uses a crossflow style muffler.
I had the coupe midpipe for about 3 weeks before using the sedan midpipe. The coupe midpipe just didn't sound quite right at certain rpms and it had some droning in the 2200-2400rpm range. The sedan midpipe has much more fluid, healthly sound. It's louder than the coupe midpipe, but it has no droning issues. As you can tell from the videos, the sound is a cross between a coupe/Z and a inline 6. IMO, it sounds perfect without being overbearing, but it is much louder than stock.
Old May 5, 2008 | 12:41 PM
clinthammer's Avatar
hearing the clip of the o6 sedan with coupe middy - I can tell u it only has a slight deeper growl.
I have an 06 sedan with hks rear section so i can say its not much of a difference. You want deeper growl go for the coupe middy.. Better to buy high flow cats though or a MD spacer.
Old May 5, 2008 | 12:45 PM
DaveB's Avatar
Believe me, I've had both. The 05/06 sedan midpipe is louder than the coupe midpipe and the setup is far louder than a stock 05/06 sedan.
Old May 5, 2008 | 01:15 PM
Wannabe6MT's Avatar
-MN G Crew-
^if you have an 05-06 sedan though you dont need to get an 05-06 sedan middy because you already have one so the only other option is to either spend a ton and get a full exhaust, or get a coupe middy.
My coupe middy is still in the garage, driving me nuts because i cant get the stock middy off...
Old May 5, 2008 | 02:24 PM
Swivel's Avatar
Moderator
Good info, thanks!
Old May 5, 2008 | 03:10 PM
DaveB's Avatar
Don't expect much of a noise change at all with the coupe middy on your 05. About the only change you'll see is the coupe middy is about 6lbs lighter.
Old May 5, 2008 | 05:33 PM
TCD's Avatar
TCD
Thanks for all the information. Based on the videos I decided to go with a 03-04 muffler on my 06 with no other changes. Found a muffler for $75 delivered.
I have Tokico/Eibach enroute. Going with Stillen intake and Hotckis sways to finish it up.
It'll be a nice daily driver.
Old May 5, 2008 | 07:43 PM
Wannabe6MT's Avatar
-MN G Crew-
Probably. But the 05-06 midpipe resonator is a lot larger than a coupes.
Old May 5, 2008 | 09:50 PM
ttrank's Avatar
Grocery getter
Cool. Good luck.
Old May 6, 2008 | 01:27 AM
DaveB's Avatar
I need to warn you that I believe you'll need this muffler bracket off of the 03/04 to make it work.
http://www.g35parts.com/9083/osc/pro...roducts_id=120
Old May 6, 2008 | 07:45 AM
  #30
TCD's Avatar
TCD
Thanks for the warning. I'll have the junkyard grab the braket as well.
