Dash kit for Double Din
Old May 28, 2008 | 01:05 PM
G35Papa's Avatar
I've searched high and low and coming up empty handed.
Before I order a regular kit for my 03 auto sedan and attempt to mod it to fit, does anyone know if there is an aftermarket dash kit that is made to go around a double din conversion console?
I want to pick up a dash kit in the real brushed aluminum to replace my Maple wood kit.
Thanks in advance for your help!
Edit: revised this thread....useful info was posted to this one as opposed to the one I posted in the interior section
Old May 28, 2008 | 02:32 PM
68_GT's Avatar
you can say accept except when you are talking about excluding something
what is the double din ? does that mean so you can run a normal size radio and something else like a coin tray underneath ???
Old May 28, 2008 | 04:57 PM
ttrank's Avatar
Grocery getter
DIN is a size. A standard size stereo is 1 DIN and they also have 1.5 and 2 DIN. The JDM V35 Skyline dash has a 2 DIN opening for a stereo.
Old May 28, 2008 | 06:09 PM
k@osx71's Avatar
I've been wondering if that as well~ I'm scared to put a navi in since my car already got broken into for a freakin ipod... it'd be nice to have a cover over the double din like that Z, even a Scion TC comes with one~
Old May 28, 2008 | 06:34 PM
ttrank's Avatar
Grocery getter
It looks very stock and is hard to remove. An iPod is easy to grab and run.
Old May 28, 2008 | 07:49 PM
G35Papa's Avatar
Engrish is my second ranguage
I think I'm going to wind up being stuck trying to cut up a OEM fitting kit.
Old May 28, 2008 | 08:24 PM
5150DS's Avatar
Did you contact Burtman industries. They have a real carbon fiber dash kit for the G35 that looks pretty good (http://www.burtmanindustries.com/zoo...p?id=g35_carb). If I remember right he (Jason Burtman) is really big into Infiniti. See if he would make an aluminum kit for the G35 if you can get enough interest on here.
Old May 28, 2008 | 08:47 PM
G35Papa's Avatar
^Great info! Thanks
I just gave him a call. He can do it...either give him the part, he takes the measurements and sends it out to get it done or I can make a paper template and he will make it to the measurements given to him. It's not cheap though. A rough quote...at least $100 and at most $200. I'm going to order the kit and start swapping out my maplewood...ad a few pieces and then consider doing the rest of the console all the way up.
If I do decided to do the rest, i'll see about a group buy for everyone else.
Thanks again.
This thread will self-destruct in 5 minutes
Edit: He did mention that the alluminum kit was about the thickness of a dime so I might be able to mod it/cut it using the right dremel bit and still achieve a good finished look. This is very encouraging and I may wind up moding the kit I purchase.
Old May 28, 2008 | 09:58 PM
Carlito's Avatar
The JDM V35 Skyline with the "Stereo Delete" option comes with a double din opening. It also does not come with dual-zone climate control. Regular V35's come with everything from Bose to navigation.
Old Jun 19, 2008 | 06:01 PM
Jason B's Avatar
I have one of the nicest brused aluminum finishes there is. There is no thick clear coat over it, and it's the raw finish.
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
WillisFL
Dec 29, 2016 08:56 AM
Crappyday
Aug 27, 2015 10:26 PM
Frankieg35
Aug 15, 2015 10:49 PM
itztwinki3
Aug 1, 2015 12:58 AM
