Mechanic A liar or being Honest?
Originally Posted by canucklehead
^ if that's the case, then the G is the first vehicle i've heard of that needs rotors with each brake pad change. every other car i've owned has seen at least one resurfacing before being under minimum spec thickness...
Probably a reason why Infinti went with less agressive pads in 05 and made up for it with larger rotors and twin piston calipers.
ugh...these rotor pad issue again.
yea - if you really want to replace the rotor every brake pad change to get that solid feel in the pedal - yea sure replace them - but your brakes will still function if you just replace your pads
FYI. After this happened to me the 2nd time at 60k miles (pads were 15k and rotors/pads 30k, like clockwork), I replaced them with aftermarket Brembo rotors, which still looked great when I sold the car 50k miles later.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
1Typhoon
Sep 25, 2015 08:45 PM
