Windshield washer fluid smellls like %^&#
Old Oct 9, 2008 | 10:59 PM
nismo714's Avatar
I've recently noticed this sewage type smell and finally realized where its coming from; the windshield washer fluid. it smells horrible, WREAKS!!
I bought this 03 sedan in march of this year. what do you guys think they did to it for it to smell THAT bad? and is there a way to flush it all out so i can refill w/ clean smelling washer fluid?
Old Oct 9, 2008 | 11:56 PM
Fabrikator's Avatar
maybe someone pee'd in it.
Old Oct 9, 2008 | 11:58 PM
Joe_Camel's Avatar
There should be a stalk on the right side of your steering column, if you pull it toward you, the washer fluid will come out all over your windshield. Keep doing that until nothing comes out, then fill up the reservoir with fresh fluid. Good luck.
express705's Avatar
use it all on the window.
just go on the highway and hit the wipers.
Old Oct 10, 2008 | 12:05 AM
Heist.'s Avatar
look to see if an animal is rotting in the reserve tank.... just open it.
Old Oct 10, 2008 | 12:14 AM
nismo714's Avatar
I seriously wouldn't be suprised, that's how bad the smell is.
I just might do that,,,, use it as a road rage tactic, stink up the car behind me!
Old Oct 10, 2008 | 12:55 AM
Nickk6's Avatar
Ya get the effin deuche bags in the left lane going 65...they need to learn where the slow lane is
Old Oct 10, 2008 | 01:04 AM
elayman's Avatar
maybe the previous owner filled it up with power steering fluid.. that smells pretty fowl
Old Oct 10, 2008 | 01:41 AM
Fabrikator's Avatar
I would probably pull the resevoir out, and dump the fluid, and rinse it out well with a hose, then purge whatever is left in the lines.. then refill with new non-urinated washer fluid
Old Oct 10, 2008 | 11:35 AM
coup de grace's Avatar
Or if you need freshly urinated washer fluid, give me a call! It doesn't smell that bad, I promise.
Old Oct 10, 2008 | 12:10 PM
racefan318's Avatar
Is there anything he could fill the tank with to do a second flush? without just wasting washer fluid?
my first thought was vinegar or something to clean out the lines and tank... then go through a couple of tanks of clean water, before refilling with new washer fluid...
Old Oct 10, 2008 | 12:32 PM
AJaxx80's Avatar
Well, you could treat it like a coffeepot...bring vinegar and water to a boil, add about 2 tbs of baking soda. MAKE SURE it all disolves and rinse your tank with it once it cools. But if you don't get it all out (lots of clean water rinse) it could leave a baking soda residue. Baking soda is the KING of removing smells. I would try running it all out and refilling with good fluid first. IF that doesn't work then resort to other measures. Maybe fighting fire with fire is the answer - coup de grace?!?!
Dallsinghjr1
Sep 17, 2023 11:25 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
