Engine gets "stuck" in the morning
Old Nov 12, 2008 | 09:26 PM
JosansG35's Avatar
When I drive my car in the morning, the engine gets "stuck" while i accelerate, then it continues normally. could it be that the engine is cold and needs to warm up?
anyone else had this problem before?
Old Nov 12, 2008 | 11:36 PM
SDGeneralCounsel's Avatar
what do you mean by stuck? You live in LA, so weather is not a factor lol
Old Nov 12, 2008 | 11:50 PM
JosansG35's Avatar
when i accelerate, the car pulls back and then lets go. it only happens once though
Old Nov 13, 2008 | 06:36 AM
1SlowSedan's Avatar
hmmm, the car hesitates to shift?
Old Nov 13, 2008 | 08:26 AM
GreenGoblin's Avatar
The goblin resurrection
not sure what stuck means?
Old Nov 13, 2008 | 11:06 AM
tthhi's Avatar
That is your ABS testing itself.
Sometimes when you first get in your car (mostly it seems to happen to me when I brake more than just a tiny tap for the speedbump in my condo complex) you can hear your ABS system testing itself. It'll make a sound similar to your car going over rumble strips (but much quieter).
I'd wager, more than likely, the strange sound you are hearing isn't your engine getting "stuck" but your ABS system testing itself.
Old Nov 13, 2008 | 12:46 PM
maciejk's Avatar
could be one of the sensors like a water temp sensor, i had this on my old supra car would run better when it warmed up, but i don't get this with my G
Old Nov 14, 2008 | 03:09 AM
JosansG35's Avatar
its not a sound. while moving, the car just stops, and continues
Old Nov 14, 2008 | 05:12 PM
playboyHD's Avatar
I think we all dont get what u are trying to explain.
first u said it got stuck. does it feel like the engine stop turning and the car is just cruising?
stop ?<do you mean that the car stops completely> we are lost here
well if ur wonder if you sould warm up ur car the answer is YES always
Old Nov 14, 2008 | 05:49 PM
maciejk's Avatar
yes arm up your car but DO NOT WARM UP your car for longer than 30secs to a minute max start driving moderately until it reaches normal temperature if u don't want to wear your cylinders out, even in the harshest winter google this and you will see.
Old Nov 19, 2008 | 01:00 PM
SixFive's Avatar
Check MAF sensor for gunk and oil residue
Old Nov 19, 2008 | 03:36 PM
Heist.'s Avatar
I think he is having the same problem I get some mornings... literally you drive a little hit the brakes then give it gas and it feels like its in neutral and then it will connect again in a second of this. Power then reaches to the wheels and slips a little....
Old Nov 19, 2008 | 03:39 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Is it stuck in 1st gear, then lurches forward with a hard shift to 2nd?
When was the last service interval on your tranny fluid?
Old Nov 20, 2008 | 01:58 AM
JosansG35's Avatar
yea it does that^^
and i dont know
Old Dec 9, 2008 | 01:53 AM
Mac8008's Avatar
happens with a lot of cars. I especially experience this problem with my e36 bmw. The manual says that it does this to help warm the engine faster.
