03 headlight swap hid question
Old Dec 6, 2008 | 04:56 AM
markp_0227's Avatar
i recently swapped my head lights to the black housing ones. my question is can i swap the HIDs to the new head lights i put in? because i do like the hids better. or does a simple swap of the stock bulbs change any difference of the bland color the new headlights have.
thanks
Old Dec 6, 2008 | 05:22 AM
G SEDAN's Avatar
did you buy the ebay headlights? Those are the only ones I know that come out of the box with "black housing".
If you did, no you cannot use HID bulbs in there. HID bulbs are not the same as stock bulbs, they require a ballast if that answers your question. the last part of your question is really hard to comprehend.
Old Dec 6, 2008 | 11:05 AM
Mustang5L5's Avatar
The ebay housings are halogen housings.
You can buy an aftermarket HID kit that fits the bulb size used by the halogen housings and fab it in, but even then the light will not project correctly since its an HID bulb in a halogen housing.
Old Dec 6, 2008 | 02:54 PM
dmitriylm's Avatar
The ebay housing is not a good choice. The reflector is not shaped for HID output and even if you got an HID kit, all it would do is glare and blind on coming traffic which would make driving dangerous for everyone around you.
Old Dec 6, 2008 | 03:27 PM
G SEDAN's Avatar
don't do it!!!
Old Dec 6, 2008 | 04:53 PM
markp_0227's Avatar
alright. sounds like a hassel. the only reason i changed headlights was to get that residue off the headlight.
Old Dec 6, 2008 | 06:24 PM
dmitriylm's Avatar
This can be done with a $10 bottle of PlastX while still maintaing the OEM HID ballast and housing, which is well sealed and doesn't fog up like the ebay ones. I just did mine recently and they are clear as glass.
Old Dec 6, 2008 | 07:23 PM
G SEDAN's Avatar
yeah should've just asked us and polished the haze off. It's from the UV rays, but its fixable/preventable.
Jusseth
Sep 13, 2020 12:25 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
