Couple of Plastic Questions
Old Dec 23, 2008 | 12:05 PM
The Stimulation's Avatar
First, I was wondering if there is a plastic cover under the hood on the driver side by the firewall, just like there is one for the battery. I saw a picture of a G's engine bay and noticed they had one and realized I don't. I don't know if it's because I have a sedan or if for some reason it was not there when I bought it.
Second, I am needing the plastic cover that is removed when changing the oil. If I can find one at a junkyard, does it matter if it's from an '03 - '04 or even from a coupe?
Old Dec 23, 2008 | 12:17 PM
mikeee2's Avatar
It doesn't come with plastic cover on driver side from factory but you can buy it online.
What you need is called a splash shield I think. It goes for $150+. Someone posted an oem part # for it on another thread a while back.
Old Dec 23, 2008 | 12:33 PM
Mmagic76's Avatar
Answer to your 2nd question:
https://g35driver.com/forums/g35-sed...otector-2.html
Old Dec 23, 2008 | 12:35 PM
Thanks guys. I actually found that thread after I posted. I'm just wondering if I can get one off another G at a junkyard, maybe one from a coupe since it may be more common or even from an older model sedan.
*EDIT: I guess I can for the underbody. What about the one for the fenders?
Old Dec 23, 2008 | 12:36 PM
Lame. Cheap *** manufacturing bastards. Thanks though.
Old Dec 23, 2008 | 12:54 PM
Beebo's Avatar
Are you looking for a JDM batt cover/brake fluid cover
PM Mike@riversideinfiniti
Old Dec 23, 2008 | 01:34 PM
This is the part I'm looking for (as circled). Pretty much the same as the battery cover, but I'm looking for the entire piece on the driver side.
Old Dec 23, 2008 | 01:45 PM
lexusk8's Avatar
When you decide to purchase the RHD (right-hand drive) battery cover, keep in mind that there are 2 versions of the part: modified and unmodified. Modified means the part has been pre-cut to directly fit that empty area, and may come with black push-style plastic clip(s) as well. Unmodified means the part has not been pre-cut, and so would require it to be cut so that it would properly fit. There is a DIY procedure posted in the forum showing how it can be cut to fit in your car.
Old Dec 25, 2008 | 12:26 PM
TOPNOTCHSEDAN's Avatar
I got the unmodified version, for only 50 bucks!!!
Old Jan 16, 2009 | 10:10 PM
Cali_G35's Avatar
where at?
Old Jan 17, 2009 | 10:01 AM
snotf's Avatar
just search jdm battery cover on ebay, and in the classifieds here. they're ALWAYS on ebay and from time to time someone will twist their car around a tree and part it out, and you'll reap the benefits.
Old Jan 17, 2009 | 11:02 AM
ttrank's Avatar
Grocery getter
I've seen the modified one for ~$65 from vendors on here from time to time.
Check with your local dealer for that under tray part. I got a new one for mine for ~$110 from my dealer.
baker2795
Sep 2, 2015 06:00 PM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
Frostbite91
Aug 20, 2015 07:20 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
