Damnit... I did the same mistake...
Old Jan 11, 2009 | 10:02 PM
O4G_ride's Avatar
In other words...
The most affordable way to repair this is to get s-tech's right? But since I don't have the sport shocks, shouldn't I might as well get stiffer and shorter shocks like the Tokico HP's so that my stocks shocks don't blow out with the s-techs??
Old Jan 11, 2009 | 10:53 PM
RussianMan's Avatar
same here but i dont mind since when i get two people in the back i get ome rubbing on some bumps
Old Jan 12, 2009 | 01:20 AM
G35Papa's Avatar
Originally Posted by OCG35
what all is involved?... does it negatively affect ride quality? Eibach Pros leave the rear a bit high - I've been contemplating different springs (or possibly coil overs) - but if the mod you reference doesn’t hurt suspension function I might try it.
Here's a DIY Mike
https://g35driver.com/forums/brakes-...mount-mod.html
As far as it affecting the ride, that depends on how much cutting you do (less cushion.....).
OP...Alot of cars don't sit at the same height from right to left in the rear and it becomes more appearant when you lower it. Those of us that run coilovers can adjust for those differences. I don't think getting S-techs is a "solution" because you may have the same result. Lowering on just springs always puts more pressure on the OEM parts so pre-mature wear is something to consider and expect. Sooner or later you will need to get new shocks...why not get it all upfront (coilovers)
Old Jan 12, 2009 | 01:23 AM
CandlestickPark's Avatar
ill Sedan
Originally Posted by G35papa
Here's a DIY
As far as it affecting the ride, that depends on how much cutting you do (less cushion.....). Alot of cars don't sit at the same height from right to left in the rear and it becomes more appearant when you lower it. Those of us that run coilovers can adjust for those differences. I don't think getting S-techs is a "solution" because you may have the same result. Lowering on just springs always puts more pressure on the OEM parts so pre-mature wear is something to consider and expect. Sooner or later you will need to get new shocks...why not get it all upfront (coilovers)
Exactly why my coils are on the way, I'm tired of my rear being too high (and the fact that I blew out a rear D-Spec shock from hitting a large uneven dip over railroad tracks going pretty fast - ouch!)
Old Jan 12, 2009 | 01:25 AM
G35Papa's Avatar
Damn....hope thats all you messed up Marcus. I didn't think D-specs where that weak. I see a large drop in your future
Old Jan 12, 2009 | 01:31 AM
ill Sedan
+1000, I better not have messed up anything else (crossing my fingers). I saw oil on my shock when I got my new tires put on last week. Its been a couple of months since I blew it, hopefully nothing else is wrong. I guess I'll find out when I get my suspension checked out when I do an alignement. We'll see how low I go the front will come down a bit, the back needs to come down a lot.
Old Jan 12, 2009 | 01:37 AM
G35Papa's Avatar
You might as well dump it Marcus...you're gonna wind up there anyways lol
Thats what coilovers are for
Old Jan 12, 2009 | 04:19 PM
OCG35's Avatar
stop - I'm begging you... stop with the coilover talk... you're making me consider them again - will the modding ever end
Old Jan 12, 2009 | 05:45 PM
G35Papa's Avatar
Want to buy my Tein CS Mike? I'm probably going to get something stiffer so I can keep riding low and dirty
Old Jan 12, 2009 | 07:20 PM
OCG35's Avatar
possibly... how many miles? Are they in good condition?... PM price please.
Old Jan 12, 2009 | 07:29 PM
nghiars's Avatar
have your springs settled yet and if it has.. sring mount can lower more than a 1/4"... depends on how much you cut off...
cremaster's Avatar
someone told me the springmount mod doesn't work for the sedans. i'm i wrong?? my rear end could drop a bit more, too.
Old Jan 12, 2009 | 07:36 PM
Jeff92se's Avatar
Red Card Crew
I don't see how it would/wouldn't work on the sedan/coupe. They share the same design.
captainL
Mar 30, 2013 11:36 AM
TunaG35
Sep 18, 2011 04:33 PM
2Evolved
NorthEast
13
Mar 25, 2006 05:00 AM
