Are these jack stands too high for our G?
#31
Rhino ramps. Each is rated to about 4/5ths the weight of the whole car.
Yeah they are plastic and very light. But they aren't built like a steel ramp. They have a thick honeycomb structure inside. It's very sturdy. I'd trust that ramp more than most jack stands. Especially if you are trying to turn a big wrench and really have to use alot of force.
#32
My Rhino ramps were useful on my car until it got lowered on Eibach springs. Now I can't ride up onto the ramps without having the bottom part of the front bumper catching the ramps' incline. I could find a couple pieces of 2x4 to lay on the ramps, but thankfully I have a floor jack and 2 jackstands to compensate this.
#33
Depends on the work you need/want to do to the G. For the regular maintenance like fluid changes, the ramps are great. You can accomplish a good amount of work under the car using those. If you plan on doing things like suspension work you'll need a jack and stands...and you can also do all the rest. Stands are the strongest when they are at their resting points (all the way down) so unless you need the clearance, always keep them at the lowest level.
Oh...and don't forget to put on the ebrake and get some wheel chocks
#34
What about when you have the rear up? Are wheel chocks in the front good enough? Since the e-brakes won't be working during that time.
#35
#36
#37
#38
I used pieces of old floor mats.
THMotorsports
Suspension-Vendor
257
12-18-2018 05:43 PM
Hogbone
09-28-2015 06:44 PM
