Sedans are as fast as coupes. go and tune
Old Apr 6, 2009 | 04:22 PM
  #151
4drmadness's Avatar
hmm time to delete the thread i guess. its become pointless
Old Apr 6, 2009 | 04:23 PM
  #152
OCG35's Avatar
Originally Posted by twitch579
I hate this ****_ng dork *** website, you guys are probably the office ***it panzees that drive around in there Coupe G35's and think they have Lambos.
Ban me I could really give a ****. Im a my350Z member anyway and never usually surf this crap Canadian Chuck Chuck AYE AYE queer site. HAHAHAHAHAHAAHAHAHA
Sedans are the Only fast g35's anyway!!!!
Welcome aboard twitch! Good to see someone with common sense in here!
Old Apr 6, 2009 | 04:26 PM
  #153
phrocker's Avatar
Is the ECU tuned to be more conservative? To me that begs the question as to what market segment the sedans were offered to. We call it a sport sedan, but why would they 'detune' it if that was the case.
Old Apr 6, 2009 | 06:46 PM
  #154
twitch579's Avatar
Its not detuned. Its just 200lbs heavier so it takes a second or two to get its *** in motion compared to a little 2 seater Z. I can't explain the RPM differences between the 2.
Old Apr 6, 2009 | 07:22 PM
  #155
OCG35's Avatar
you keep comparing the sedan to the Z - where the majority of the thread is about sedan vs coupe... I think the post you are responding to is asking about ECU factory tune vs coupe - but it pertains to Z as well... and yes, there have been indications over the past several years of various dyno testing that sedan's ECUs are "detuned" (if you want to call it that)... as for "why", since they market it as a "sport sedan" - it's still a sedan and the vast majority of the buying public will not use it at a race track or even the type of spirited driving that more coupe owners would...
As for the sedan against a Z... I've beaten plenty of Zs. I've said it before, when I test drove the Z initially, it was the most fun to drive car I had ever driven... if it weren’t for the business needs I had at the time, I would have bought the Z. But that doesn’t mean the sedan can’t be made to compete with it
As for weight – my car weight out at 3380 fully loaded with all the normal crap in the trunk, all mats, with 19” wheels… forget about “manufactures” weight – this weight is close to what the majority of Zs would be running – probably less than a lot of them that got pig heavy wheels and bloated sound systems. I know it’s embarrassing to have your @ss handed to you when you line up next to a 4-door… I’ve talked with Z owners after I’ve smoked ‘em and they are usually perplexed.
Old Apr 6, 2009 | 07:24 PM
  #156
Wannabe6MT's Avatar
-MN G Crew-
A couple ?s about tuning.
1. My shifts some times feel rough. Like, not like the tranny is going out or sotmhing, idk how to explain it. But would a tune smooth out my shifts? i am 5at.
2. What is the one to go for?
3. Will my car return to a stock ECU setting if i ever decide to remove all the parts and put it back to stock, or will it run like crap?
Keep in mind, i have an HR y-pipe, coupe midpipe, HKS axleback, Z tube, pop charger, and an MD 5/16 copper spacer.
Old Apr 6, 2009 | 09:21 PM
  #157
AceG35X's Avatar
haha I did misuse the word "your", although I did spell it correctly. I should post my English papers here because you guys are better than Microsoft spell check any day.
BTW Janik, you never got your car tuned after all the exhaust work? I've heard after HR Pipes, HKS axle back, and your coupe middy you should def. get a tune. I'm not 100% sure on the shift smoothing out, but i do understand what you mean by it feels "sticky"
Old Apr 6, 2009 | 09:32 PM
  #158
Wannabe6MT's Avatar
-MN G Crew-
How much do tunes normally cost and can i get it done at my local performance shop?
Old Apr 6, 2009 | 10:02 PM
  #159
twitch579's Avatar
itunes.com $1.00 per tune.
The Sedans ECU is not De-tuned. Explain why then how you can flash a map from a Z right onto a Sedan and it works perfectly?!
Its the SAME exact powertrain with slight drivetrain modifications for the different lenths of the cars. Its all the same stuff, these arent hand built Lamborghinis, there mass produced Nissans. The differences in speeds comes from the weights of the cars and the ability to put the power down without mechanical and drivetrain loss.
The coupe being the longest and most heavy would naturally be the slowest.
Sedan VS Z is almost a Drivers race, the Z will have the slight edge in speed....barely.
Old Apr 6, 2009 | 10:14 PM
  #160
DaveB's Avatar
I've got a lightweight 03 sedan. Last year while working at a Fed-Ex Freight facility, I put my G (fully loaded) on the scales. With me (180lbs), 1/2 tank of fuel, and about 60lbs of gear in the trunk, the car came in at 3650lbs or roughly 3,410lbs with a 1/2 tank of fuel. A Fed-Ex driver (200lbs) put his 04 Z Track with about 1/2 tank of fuel on the scale and it came in at 3420lbs. That means the Z weighed about 3,240lb. That's a 170lb difference. I don't where people get the idea that the Z is as heavy as the G sedan. I've seen it first had. It's not. It's significantly lighter. For whatever reason, Nissan's curb weight (that means ALL fluids and fuel) rating is slightly overestimated.
Go over to My350Z.com and you'll see that stock Z's are typically .2-.3 seconds and 2mph faster than the G sedan, tranny to tranny. There are a handful of stock VQ35DE Zs that have gone 13.6-13.7@102-103mph. Find me one stock 1st gen G sedan that's come close to that. I've beaten Zs at the strip, but I'm not fooling myself into thinking my car was faster. I know for a fact that if I was driving a Z, I would be quicker in it than my G.
Old Apr 6, 2009 | 11:50 PM
  #161
G SEDAN's Avatar
YO bro, the Z's are way faster bro! you wanna know why bro?! I got two words for you bro.
z-tube!!!!!!!
Old Apr 6, 2009 | 11:54 PM
  #162
4drmadness's Avatar
oh add z springs to that
z-tube!!!!!!!
Old Apr 7, 2009 | 10:23 AM
  #163
canucklehead's Avatar
in support of this, while at a local strip last year my friend (with an '03 Z, 6spd) and i weighed our cars. with me in it (195lbs) and 1/2 tank i came in at exactly 3600lbs. my buddy (225lbs) in the Z and 1/4 tank weighed 3460lbs. that equates to 170lbs + ~30lbs for 1/4 tank = 200lbs difference in weight.
why are we talking about Z's again? i thought this thread was comparing G sedans to G coupes? now can we /thread?
Old Apr 7, 2009 | 11:05 AM
  #164
phrocker's Avatar
De-tuned might be a poor word choice on my part, but we were implying a conservative factory mapping. I can understand tuning with mods, but I've read in old threads that an orisis tune can in fact help a stock G, which implies that the stock mapping is conservative.
The previous answer is probably right. It's a sedan, so they wanted to shoot for all market segments.
As far as the lower weight, does this apply to 05/06 sedans? Any 05/06 hit the scales?
cars.com lists the 03/04 at 3369 and the 05 at like 3512...so clearly there was a weight gain. This could account for your lower weights. In addition, there is going to be a difference between mt/at
Old Apr 7, 2009 | 01:21 PM
  #165
OCG35's Avatar
if you've seen as many Z, coupe and sedan dynos you'd realize there is something to the ECU... dyno has nothing to do with weight.
