Quote:
Everything I see says they have the same wheel base, thus same drive shaft length.Originally Posted by bonkrokz
longer driveshaft then coupe and z, i think the z and coupe have c/f driveshafts aswell where sedans do not ..plus overall its a longer distance from the motor to the rearend ..
Never heard either the G or Z had carbon fiber driveshafts before and I highly doubt it.
^really... how much longer are sedans that coupes? From t-case to drive shaft? I'm going to speculate a bit and argue that the difference isn't much, perhaps even non-existent.
Hotdawwgman
close
- Join DateFeb 2008
- LocationSoCal/Chicago at Heart
iTrader Positive Feedback100
iTrader Feedback Score(19)
Liked:124 Times in 109 Posts
5150DS I like your sig! hahaha
Quote:
Are you agreeing or disagreeing with me?Originally Posted by RPL
Thanks HotDawgman, it gets lost on some though.
Z definitely has CF - coupe does not (as far as I know)... and coupe shaft is not shorter (as far as I know)...Originally Posted by 5150DS
Everything I see says they have the same wheel base, thus same drive shaft length.Never heard either the G or Z had carbon fiber driveshafts before and I highly doubt it.
Are you agreeing or disagreeing with me?Thanks HotDawgman, it gets lost on some though.
Oh, my bad! I agree. I was disagreeing with bonkrokz. We must have posted at nearly the same time. :P
Jeff92se
Red Card Crew
close
- Join DateMay 2005
- Locationɐʍ 'ǝlʇʇɐǝs
iTrader Feedback Score(24)
Liked:585 Times in 498 Posts
Z is lighter than both the sedan and coupe. IMHO, that's where the performance differences are.
My 03 sedan weighs less than the 06 Z from numbers I saw a while ago. Not by much though, around 50lbs if I remember right.
Z Uses a C/F driveshaft? Why don't we see more threads about people swapping driveshafts? Especially in the automatic models, as you would gain back some of the pathetic drivetrain loss our slushbox has.
Quote:
97% of people who use the term "pieholes" have never passed a basic statistics course, so I find it hard to take you seriously.Originally Posted by Texan1
did you know that 86% of all people that make up stats on the spot are 94% more likely to have someone tell them to shut their pieholes
Quote:
Both are about 3340lbs, but the Z will have a substantial power advantage.Originally Posted by Lucky-G
Quote:
Because the Z's driveshaft should be shorter.Originally Posted by Lucky-G
Agreed, the Z will have quite the power advantage--stock for stock
I see what you did there. No C/F Z shaft for me
Quote:
350Z Wheelbase = 2,649 mm (104.3 in)Originally Posted by Jeff92se
Z's crankshaft is shorter??
G35 Wheelbase = 2,850 mm (112.2 in)
Since they have the same engine/tranny, the driveshaft has to be shorter in the Z.
Quote:
5whp if that is substanial?Originally Posted by 350Zed
5ATs only give up 10whp/10wtq to the 6MT. It's not the significant, especially from 0 to 100mph.Originally Posted by Lucky-G
MyZ Uses a C/F driveshaft? Why don't we see more threads about people swapping driveshafts? Especially in the automatic models, as you would gain back some of the pathetic drivetrain loss our slushbox has.
