Sedans are as fast as coupes. go and tune
Old May 15, 2009 | 11:40 AM
  #181
OCG35's Avatar
Originally Posted by Klubbheads
marketing bullsh!t. Any year coupe or sedan including G37s will not blow their engine on 87 octane. They will be slow as **** but nothing will happen.
I believe an electronic arm pops out of the dash and slaps accross face.
But other than that, you'll be fine.
Old May 15, 2009 | 11:44 AM
  #182
Klubbheads's Avatar
This thread has some of the funniest quotes to put in the sig. I don't know what to pick. LMAO
Old May 15, 2009 | 12:03 PM
  #183
RPL's Avatar
RPL
^LOL Klubbs, I just noticed that I made your sig! Sweeeeet I wish I had a c/f drive shaft
hahha
Old May 15, 2009 | 12:16 PM
  #184
OCG35's Avatar
hahha
I know where you can get one made... I thought about it, but I'm going to let someone else be the guinea pig on that one (for now)... eventually I'll probably do it.
Old Dec 11, 2009 | 10:09 AM
  #185
Kuneff's Avatar
My G coupe has outran a 350z.
Old Dec 11, 2009 | 05:00 PM
  #186
Blue Dream's Avatar
I drove ttrank's car solo
^^ You suck. I was hoping for a good race video.
SBF!!!
Old Dec 11, 2009 | 05:04 PM
  #187
OCG35's Avatar
SBF!!!
Old Dec 11, 2009 | 07:14 PM
  #188
NjMatteSedan's Avatar
Originally Posted by DaveB
I'm not quite sure where you're getting your information regarding tire weight, but a quick check of tire weights on TireRack shows that, on average, 215/55R17 tires are generally 2 to 4 lbs lighter (24-26lbs) than a 245/40/19 (27-30lbs). The OEM 17s weigh in the 24-25lb range and the coupe 19s are very close to that (within a pound). I'm not surprised your aftermarket 19s are lighter (probably close to 20lbs), but the tires make up the loss when compared to the 17" OEM setup.
Then there's two other major factors at play:
1) With larger rims, the mass of wheel/tire is further from the hub which makes it harder to accelerate.
2) Wider rims/tires and sticky tires greatly increase drag and wind resistance. A 245/40/19 is over 1.5" wider in profile. That's a big increase in drag.
My aftermarket 18" combo weighs 1lb less overall than my OEM 17s. The width of the 18" combo is 1.2" wider than the 17s. Overall, when I swap rims, my MPGs drop a solid 1-2mpg. That means the car is using my fuel/power to overcome the drag.
Wrong the coupe 19s are not within a lb of the OEM 17s. Theyre like 4 lbs lighter. The oem 17"s are 24-25lbs, the coupe 19's are 20lbs FR 21lbs rear
Old Dec 11, 2009 | 10:41 PM
  #189
Tollboothwilley's Avatar
pretty sure my 245/35/19s weigh in at 25 lbs
Old Dec 12, 2009 | 12:25 AM
  #190
^ oh i thought he was talking about the weigh of the rim itself
jsimonk
Dec 22, 2023 03:49 PM
vmcarbuyer
Oct 12, 2019 12:42 PM
MR M37s
Oct 30, 2015 08:32 AM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
Red G Coupe
Tuner & Dyno
Jul 30, 2015 08:32 PM
