3rd tail light as bright as Jessica simpsons personality
Old Mar 4, 2009 | 01:43 PM
BJD275's Avatar
My 3rd brake light will be bright as hell one moment then randomly gets dim while on the brake peddle. Any one know what this is about or have the same problem? I tried searching and couldn't find any thing on it.
Also about to do my tranny fluid is it the synthetic or regular fluid?
Old Mar 4, 2009 | 01:48 PM
Jeff92se's Avatar
Red Card Crew
Mine was working irratically but it was on / off. I finally replaced it. WHAT a total pain. There's no reason at all to make the far right mounting screw THAT hard to get at. I was ready to use a hole saw to make an access for it. But I finally got it out and installed the replacement with only one screw. It's been holding up okay. I think I used double stick tape for the other side.
Old Mar 4, 2009 | 11:51 PM
mrdwaters's Avatar
It's pretty common. Some people replace a diode for 14¢ and say that does the trick.
A new LED assembly is over $100.
Here's similar thread:
https://g35driver.com/forums/lightin...nctioning.html
Old Mar 5, 2009 | 09:15 AM
subsonic816's Avatar
Just wanted to give you a bump for the awesome heading on your post ... outstanding my friend, outstanding!
Old Mar 5, 2009 | 01:19 PM
Heist.'s Avatar
yeah amazing title
Old Mar 5, 2009 | 10:28 PM
fleishelja's Avatar
does anyone have a pic of the burned out diode or will it be obvious which one is burned out when i take it apart?
Old Mar 6, 2009 | 10:40 AM
BJD275's Avatar
I have it under warranty still (a lexus gold warranty) that supposedly covers everything except brake pads and burnt out lights and stuff like that so I wonder if they'll fix this since it is a diode and not a light burnt out.
Also thanks for the comments on the title, if you want attention you have to have a clever hook.
Old Mar 6, 2009 | 10:59 AM
canucklehead's Avatar
when i think of jessica simpson her sparkling personality is not the first thing that comes to mind...
as for warranty coverage, give your dealer a try. gather your information so when you speak with them you are well informed. if this truly is an electrical problem then don't let them bully you into paying for what should be covered by the warranty. hopefully this isn't one of those annoying electrical problems that seems to go away whenever you get near a dealer.
Old Mar 6, 2009 | 11:41 AM
BJD275's Avatar
It is, last time I went in they said they couldn't repeat the problem
even after I told them it was sperattic so they just didn't fix it.
And a lot of things come to mind when thinking about Jessica Simpson but this would not be the appropriate place to discuss those LOL.
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
roboeclipse
Lights
Aug 13, 2015 10:45 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
