Do i need spacers?
Old Mar 26, 2009 | 08:42 PM
Cali_G35's Avatar
Do i need spacers?
I have bone stock g35 sedan and i was wondering if i need a spacer for 19'inch 9.5, 5-4.5 (5-114.3), +35 offset.
ps. not planning to lower the car any time soon.
Old Mar 26, 2009 | 09:11 PM
g35freak86's Avatar
you should be fine with that offset. it should actually be pretty flush
Old Mar 26, 2009 | 09:23 PM
FlyingLumpia's Avatar
is that front and rear or just rear you are putting those on.
Old Mar 26, 2009 | 09:25 PM
Cali_G35's Avatar
both front and rear. What kind of tires spec do you guys recommend?
Old Mar 26, 2009 | 09:31 PM
g35freak86's Avatar
I just assumed it was the rear specs. Not quite sure if you'll be able to get away with a 9.5 in the front. It'll be close
for a 9.5 rear... best tire size (IMHO) is 275/30
Old Mar 27, 2009 | 10:41 AM
ttrank's Avatar
Grocery getter
Nope on the 9.5 up front unless you want them to stick out. I believe that offset may hit the inner arm if you ever do lower it.
Old Jun 13, 2009 | 11:31 AM
danster5's Avatar
Need help. M45 rims on 03' sedan
New to this forum. I just picked up the m45 rims (50 offset), i have a o3' g35 sedan stock. What would be the best spacers to use? im looking for that flush look. well 10mm w/ extened studs be ok? well i need for the back as well? Please help?
Old Jun 13, 2009 | 11:59 AM
bowzer's Avatar
The fronts will fit w/the offsets listed and a 245 or 255 series tire. It's a close fit on the arm, just a few mm clearance.
I have 18x9.5 front w/+35 offset and a 245/40/18 tire, but am sizing up to a 255/40/18 shortly.
Old Jun 13, 2009 | 12:09 PM
danster5's Avatar
The m45 rims are 19x8.5 front and rear. Tires 245/40/19. well 15mm spacers make my tires stick out,
Old Jun 13, 2009 | 12:14 PM
STCLAIRWEST's Avatar
I thought they were 8 all around?
Old Jun 13, 2009 | 12:37 PM
Are you lowering it, if so 15 is great. Actually thinking about it. 15 should be great even if you dont lower it.
Old Jun 13, 2009 | 12:46 PM
danster5's Avatar
At this time i wont be lowering it. well 15 look flush?
Old Jun 15, 2009 | 08:14 AM
BIGD28's Avatar
Get a level and tapemeasure and measure
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
