G35 Sedan Suspension Picture Compilation Thread
i just put on the eibach 1.1 all around springs with just some 18inch rims and low pro tires.. and im rubbin i think.
when i go over bumps at any speed greater than 5mph it rubs.. how can i fix this?
thanks
thanks
nope. Had 245/40/18s in that pic and no issues. Running 255/35/19 out back and still no issues.
Pic w/ settled S-techs and OEM Rays:
Specs
Front 19x8 +30 w/ 225/40/19s
Rear: 19x8.5 +33 w/ 255/35/19s
Specs
Missouri, are you running a camber kit/rolled fenders with that set up? I think people should start adding that in to the description too. And I think Blue Dream Should get the s-Techs and pass down the H techs
haha just sayin'
haha just sayin'
Hey guys... I need some advice...
I want to tighten up the handling on my '06 sedan with the sport suspension, riding on OEM sport 18's. I find the rear end gets unsettled (wobbles) during quick transitions, so I'm thinking tougher sways would fix that. I also want a slight drop for cosmetic reasons. Note: I don't do any track work--I'm all-street, with about 80% highway miles.
I think the Hotchkis or Stillen will do the trick for sways, but what about the drop? 350Z springs? G coupe springs? Aftermarket?
If someone could recommend springs, as well as suppliers who will ship to Canada, I'd appreciate it (incl. Z/G stock springs... where the %^&$ would I get them from?)
Keep in mind, I don't want to sacrifice too much ride, because of all the time I spend on the highways.
Thanks!
Here she is stock... needing sways and a drop...
Thanks!
IMO sways are the single best mod for what you're looking for, zed, and a set of Z springs/shocks (or Z front, G coupe rear) from the Marketplace either here or on my350z/kijiji/Craisglist will give you that slight drop. Easy!
If I go with Z/GC springs only (keep my sport shocks) do I need to worry about camber?
Just keep an eye pealed for leaks on your shocks. They will go bad within a year. Sooner if you drive them hard. You can put Z shocks on there, but I recomend the TOKICO d-Spec shocks.
i dunno about the year thing, i have the tanabe springs, witch is like almost a 2" drop with my stock sport shocks....going on 3 years now and no leaks yet
