G35 Sedan Suspension Picture Compilation Thread
Old Aug 29, 2011 | 03:42 PM
  #811
MPJ's Avatar
MPJ
Originally Posted by chinleewan916
Im changing springs only, so its 1.6 drop all the way around using 350z s tech, that means im better off using s tech for g sedans because its advertize to do 2in front/ 1.3 rear. Any suggestions?
Are u sure about that drop for sedan springs? That don't sound right. I have tein s-techs for a 350z plus shocks and struts for the z as well and love it. I had no probs with it rubbing.
Old Aug 29, 2011 | 05:47 PM
  #812
chinleewan916's Avatar
Originally Posted by JaE35
i wouldn't run 350z stechs on your stock sedan shocks...you'd murder them in a few months....what you get out of the z springs are outstanding spring rates
So tein s tech Gsedan springs would be little more easy on my shocks? Sorry im asking a lot of questions. Just doing some research.
Old Aug 29, 2011 | 05:51 PM
  #813
JaE35's Avatar
Moderator
G35 Sedan
exactly, the sedan ones obviously were designed to work well with the stock suspension....i like the drop of the sedan H&R springs
good thread to flip through
https://g35driver.com/forums/brakes-...nsion-pix.html
Old Aug 29, 2011 | 07:40 PM
  #814
https://g35driver.com/forums/g35-sed...on-thread.html
Thanks a lot for the info, ive looked at the h&r but it was'nt a much of a drop.
Old Aug 31, 2011 | 02:18 AM
  #815
SDGenius's Avatar
Old Aug 31, 2011 | 01:52 PM
  #816
d0nutboii's Avatar
^^ Lol, i wish i had the money.
Old Aug 31, 2011 | 06:50 PM
  #817
SDGenius's Avatar
Old Aug 31, 2011 | 09:32 PM
  #818
RaheemG35's Avatar
Sweet set-up......
Old Sep 1, 2011 | 12:16 AM
  #819
jookyshank's Avatar
I haz hugz to givez
Hey M, confirm something for me...have ya gone out and done any "spirited" driving yet on the setup? I know you were waiting for some toe bolts or something...but I'm hoping your will would be as weak as mine would after such an install
question is...how does it feel? once it's "aired down" you can't even tell the cup portion exists correct?
danke!
(oh yea...BAAAAAAAAAAAALLLLLLLLLER **** shiz!)
Old Sep 1, 2011 | 02:40 PM
  #820
rtito20's Avatar
Does the 06 350 Z suspension fit on a 03 g35 sedan?
Old Sep 1, 2011 | 03:37 PM
  #821
NFSP G35's Avatar
? = 2B || !2B
^yes
Old Sep 6, 2011 | 07:56 PM
  #822
FlipGarcia's Avatar
Got a ? Lowered my car 6 months ago w tanabe springs n now looking for a front camber kit? Is all I need the upper control arm or ne thing else.. Ne suggestions would b appreciated.. Thanks
Old Sep 6, 2011 | 08:05 PM
  #823
Blue Dream's Avatar
I drove ttrank's car solo
Do you want the good news or the bad news first? Good news is all you need to replace is the front upper control arm. The bad news is there are only 2 sets still being made that will give you any significant positive camber adjustment and they are both hella expensive. SPL or SPC
I prefer the SPL; they're easier to install, cause fewer issues with the ABS, and have a LOT of positive camber adjustment at over 2 degrees available.
Old Sep 7, 2011 | 01:07 PM
  #824
FlipGarcia's Avatar
What's the diffence? N u got ne links to get the spl ones? Found sone spc one looking to get then ASAP... Car is down so wanna get it up n running again... Thanks
Old Sep 7, 2011 | 01:43 PM
  #825
Texasscout's Avatar
Dood, if ur tiepg on ur pone, take more time. Otherwise leave the Twitter speak on your phone....
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
