G35 Sedan Suspension Picture Compilation Thread
Rating: Thread Rating: 4 votes, 4.75 average.
Old Sep 26, 2013 | 11:28 PM
  #1456
Texasscout's Avatar
compressed or cut?
Old Sep 26, 2013 | 11:34 PM
  #1457
vxgel's Avatar
Originally Posted by Texasscout
compressed or cut?
compressed man, smooth ride too.. not that rough, i was expecting worst!
Old Sep 28, 2013 | 09:44 AM
  #1458
Chucks 04's Avatar
Originally Posted by vxgel
compressed springs until i get airbags
What size rims... Nice drop
Old Sep 28, 2013 | 07:36 PM
  #1459
vxgel's Avatar
20x10 (rear) 3.5' lip
20x8.5 (front) 2' lip
+32 offset
Old Sep 29, 2013 | 09:49 AM
  #1460
Chucks 04's Avatar
+32 offset
That sweet.... This might be a slow question but what is the off set on a rim for instance +32 and how do u fig that out
Old Sep 29, 2013 | 11:41 AM
  #1461
vxgel's Avatar
Thats hard to explain man, basically how far the rim sits in and out, if it has a higher offset it will sit further out.. like poke out, the smaller the offset is the more inside it will go.. so for an aggressive look go with a 30+ offset.
Old Sep 29, 2013 | 01:04 PM
  #1462
Chucks 04's Avatar
Thanks for the explanation... Keep it Kleen
Old Sep 29, 2013 | 01:07 PM
  #1463
Mosheh1am's Avatar
It's actually the opposite. The offset of a wheel is the distance from the mounting surface of the wheel to the true center-line of the rim. A positive offset means the mounting surface of the wheel is positioned in front of the true center-line of the rim (this in effect brings the tire in to the fender well more). A negative offset means the mounting surface of the wheel is behind the true center-line of the rim (this will cause the tire to stick out away from the vehicle)
Old Sep 29, 2013 | 03:39 PM
  #1464
Texasscout's Avatar
Give that man a cigar.
This will explain it much better than I ever could. Put your original size on the left, then try different combinations on the other side. It will show you how it will change things.
http://www.rimsntires.com/specs.jsp
Old Sep 29, 2013 | 10:36 PM
  #1465
mindbeats's Avatar
http://newjersey.craigslist.org/pts/4017842152.html
hey i found these and was wondering if theyre worth it? I have a 2006 g35x and was gonna go with tein h techs but then i found these and they raised my curiousity. Ive been looking through this thread all day. I have 19" 5zigen 5zr wheels and am looking to close the wheel gap but still maintain as much of a comfortable ride quality as possible as this is my daily and i drive about an hour to work. I intend on purchasing aftermarket shocks, Tokico HPs or D-specs, again w/e will provide me with the most comfortable ride to stock as possible. I know this has been beaten down over and over and over but im just seeking some advice from those with experience.
Old Sep 30, 2013 | 12:01 AM
  #1466
Mosheh1am's Avatar
Never heard of these type of springs. The look real aggressive though, since they're on a coupe you'd be lower; and I'm not sure how well the x would cope with these on jersey roads. Test it out.
Old Sep 30, 2013 | 12:20 AM
  #1467
mindbeats's Avatar
Lol yea these jersey roads are exactly y I'm being extra cautious with what I buy. I don't want super aggressive I just want low enough lol if they makes any sense. I'm not willing to compromise my ride comfort to such an extent just for looks so ill pass these up but thanks for your help. I'm real interested in the Z/G setup as I believe IMO anyways that using 350z struts/shocks and the z/g springs will allow me to maintain that nice luxury comfort will improving stance. Thanks again for the input
Old Oct 2, 2013 | 03:48 AM
  #1468
j0rg3's Avatar
quick question I'm new to g35s, will 350z aftermarket lowering springs fit a 03 g35 sedan?
Old Oct 2, 2013 | 04:51 AM
  #1469
Blue Dream's Avatar
I drove ttrank's car solo
Yes but they will lower the sedan a full inch more than they do on the Z. Take that into account if you're looking at some.
Old Oct 2, 2013 | 08:53 AM
  #1470
North NJ G's Avatar
I have a X and i also live in NJ. I know the rodes could be a little banged up in some areas but, it is not that bad. Why not just save up and get some BC coils? You will be able to get the ride height you are looking for. I don't know if you have lowered the X before, but be ready to go through multiple CV boots.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
