Improving Gas Milage: Tips ?
Old May 30, 2009 | 02:40 AM
DUNKMAN23's Avatar
I get pretty decent gas mileage on my G, about 350miles a full tank.
But is there any tips you guys have to get more?
Old May 30, 2009 | 02:51 AM
4DGS's Avatar
Don't do any performance mods that might make you want to accelerate heavier. Or you might only get 250.
Old May 30, 2009 | 02:55 AM
jinpoky's Avatar
I only get around 300 the most
Old May 30, 2009 | 07:59 AM
pwebb's Avatar
increase the average distance between the gas pedal and the floor.
Old May 30, 2009 | 10:48 AM
Blue Dream's Avatar
I drove ttrank's car solo
You're getting good mileage already. Not much else you could do. Maybe buy a Prius
Old May 30, 2009 | 10:51 AM
Swivel's Avatar
Moderator
Best advice: fuggedaboutit. Not much you can do except drive like a granny, and even then you won't see great gains (nor will you have any fun!)
Old May 30, 2009 | 01:05 PM
STCLAIRWEST's Avatar
Im lucky to get pass 350 KM, 300 miles will be perfect for me.
Old May 30, 2009 | 01:41 PM
4DGS's Avatar
WHAT!?
I get 800kms on the highway?
maybe 450ish in the city.
Do you drive downtown all day?
Old May 30, 2009 | 03:51 PM
I live midtown toronto, your city driving isnt like toronto and im sure of it. So by my caculations if you drove in toronto it would probaly be the same.
Old May 30, 2009 | 03:59 PM
xratedg's Avatar
I get about 18 MPG on a consistent basis.
Probably about 80%city.
Old May 30, 2009 | 04:08 PM
Swivel's Avatar
Moderator
EM gets better mileage than all other colours.
Old May 31, 2009 | 12:39 AM
4DGS's Avatar
hah yea that's why I asked, more idling then driving.
But swivel is right, green is eco-friendly and saves gas.
Old May 31, 2009 | 12:52 AM
Bigrose's Avatar
OP, how many miles on your car??
It you are around 100k, change your spark plugs. Also, regardless of mileage on your odo, check/change/upgrade your air filter. Drain and fill all other fluids in the car. Get a fuel system cleaning done at a service center or dealership. Switch to synthetic oil if you haven't already. If you are easy on your car try a 0W-20 oil like Eneos. Use premium gas if you don't already. Use your cruise control as much as possible.
Alot of this stuff is regular common knoweldge stuff that rings true for any make/model of vehicle. Even if you do all these things, you probably still won't see a HUGE increase in mpg. Like everybody has already said, the G wasn't made to be a super fuel efficient car and the VQ isn't a super fuel efficient engine.
Good Luck! Hope this helps! At least gas isn't as expensive now as it was last summer!
Old May 31, 2009 | 11:05 AM
kevink's Avatar
If this is all city, it is better than my 04. I get about 16+mpg in the city, so your 17.5 beats it.
But I get 20.8 mpg overall, city/highway, so that doesn't look good if you drive highway.
Old May 31, 2009 | 03:59 PM
Dan in St Louis's Avatar
2004 G35x, heavy right foot.
Best highway tank = 21.4 mpg
Overall average, mostly city = 16.5 mpg.
