new starter??
Old Jun 30, 2009 | 12:28 PM
  #31
mikeee2's Avatar
Originally Posted by ttrank
Optima Red Top 34R.
Starter should be fine. One of my turbos sits right on top of my starter and after 2.5 years in Phoenix I'm still ok.
(I do have a spare just in case but it will be a bbbbiiiiiiiiittttttttccccchhhhhhhh to put in). LOL
Just curious, is there any the advantage of running Optima Red Top 34R over let's say a Diehard that is picked up from Sears if your car is stock?
I always hear good things about Optima and I'll need to replace my battery sooner or later. I am still on the oem battery but cranks fine.
I just did a look up on the Optima website and for RedTop it said "35". Also read some threads and some used 34R and another DIY thread uses 35. What's the difference? The R is reversing the + and - right? So Optima battery post by default is different than our car battery?
Standing in front of the car, Neg is to the left and Pos is to the right so regular Optima battery is Pos on the left and Neg on the right?
Old Jun 30, 2009 | 02:46 PM
  #32
350GT-R's Avatar
mine is doing the same exact thing....
changed everything already...
maybe its time for a new battery...
will 500packs of energizer works? (LMFAO JK)
hey how bout trying to start ur car with a 9v, i wanna try that! lol
Old Jun 30, 2009 | 03:11 PM
  #33
blownvert's Avatar
Originally Posted by mikeee2
It's funny reading this thread. Blownvert you have a few options and I am not being sarcastic.
1) Continue living in a fairy tale where things just lasts forever and fixes by itself
2) Start out by examining one of the obvious (battery). You car is 5 yrs old, the battery can die any minute. I bought this tool last month, cost me $15 bucks I think and you can check your battery life WITHOUT OPENING THE HOOD.
https://g35driver.com/forums/g35-sed...etty-neat.html
What's so scary about opening the hood anyway? Also, if you ever plan to get another car, you'll need to maintain it, otherwise get a lease.
i have a built in volt meter through my navi indash, but anyway seems like i need a new battery. buy online or just go sears?
Old Jun 30, 2009 | 04:41 PM
  #34
5150DS's Avatar
It doesn't matter where you get it from, just make sure you get a decent warranty with it. The one I got from Auto Zone has a 3 year free replacement warranty and is prorated after that, up to 7 years.
Old Jun 30, 2009 | 05:04 PM
  #35
Mustang5L5's Avatar
Volts really only tells you the output of the alternator.
Only way to test the battery is to put a load on it using a tester similar to this
It has a resistor which loads up the battery and then it measures how much current it can pass through.
If you go to Autozone they can test it. Sometimes you don't even need to take it out of the car.
Old Jul 1, 2009 | 09:20 PM
  #36
blownvert's Avatar
whats the stock infiniti battery cranking amps? how much cranking amps should i get? i dont care about performance, when the time comes i just want to replace battery with basically same one.
chinee
Jun 10, 2024 07:48 PM
magnetism80
Feb 1, 2019 10:00 AM
Joe Gargano
Sep 18, 2015 11:17 AM
dimentio1
Aug 16, 2015 11:47 AM
chinee
Aug 8, 2015 10:11 AM
