Good idea... 8" sub...
I suck at this audio eletronic stuff, but IIRC.... stock bose headunits amplifies each speaker. That's why a lot of people are saying when they got a better headunit, the sound is "better".
I feel like my radio sounds better.....but it could be the placebo effect or just because I'm getting better sound input through my ipod.
What did you replace the speakers with? Did you run them off of the factory amp and head unit and if so, did it sound any better?
i was afraid the stock bose sub was amplified. so just replacing the speaker won't make a huge difference if it's not powered by additional juice.
and +100000000 on not wanting to lug around a sub box in the trunk. been there, done that.
I guess the question then is how many watts does the factory amp push. Some of the 8" subs I was looking at earlier run on 35-100 watts RMS. The difference in ohms between Bose and the rest of the world probably comes into play too. I'm pretty sure Bose runs at 1 ohm while everything else is 2, 4 or 8. It's been a while since I've messed with car stereos, but if you put in a 2 ohm I think it would basically cut the wattage in half.
you get one of those little converter harness thats how i have mine hooked up i got lucky.
i can control my sub amp w/ my radio bass **** and treble ****.
and my stock sub and my 12 works together, it sounds great. and i didnt even have to take out the radio you hook it up in the back thru the speaker wires
the 8" jl W1v2 subwoofer fit right in with no mod. i did also install a 200watt amp to power it. it sounds much better than stock. it uses the trunk as a box or free air... im happy the sub cost 100 and i believe if you use the stock amp it would work...
He used a LOC to convert the high's into low and then feed them into an aftermarket amp/sub. This is how mine is done too, no messy wiring to the head unit.
im using a one channel fosgate amp. i also upgraded my stock speakers to infinity kappas... i think they are 2ohms or 4ohms... which ever that matches up to bose head unit...
