Offset Officials please chime in!!!
Old Jul 3, 2009 | 12:42 AM
wilboytsk's Avatar
Need a quick answer fellas..
I'm dropped on tein htechs/sedan running 19x8.5 w a 40 offset
found a set of 18s with the following specs:
size : 18 x 9.5 inches wide
offset: +30 and +25 staggered look
bolt pattern 5 X 114.3
How will these look and are they even worth getting...any info is much appreciated. Thanks!!!
Old Jul 3, 2009 | 12:47 AM
Jeff92se's Avatar
Red Card Crew
9.5" and 25mm might be a problem. I'm on 8.5" and 30mm and I don't have much to spare. Your 1/2" wider and 2.5mm wider on the outside. Well it might be close with the right tire and camber
Old Jul 3, 2009 | 04:16 AM
BuckeyeInMI's Avatar
Coupe 18's are 8" and +30, and just about perfectly flush on a Sedan. Your fronts are .75" wider (each side) and 5mm farther out, so almost an inch farther out than mine. Too much in my book. The rears will be a better fit, but still not great.
Old Jul 3, 2009 | 04:21 AM
FlyingLumpia's Avatar
Stretch a 245 on there and you will be good.
Old Jul 3, 2009 | 04:22 AM
Also drop it more so you can have more camber.
Old Jul 4, 2009 | 05:09 AM
wilboytsk's Avatar
Thx fellas...going to stick to 19 m35's...can I go with a 265/35 in the rears without rolling the fenders?..i do have some neg. camber back there
Old Jul 4, 2009 | 05:41 AM
OCG35's Avatar
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jul 4, 2009 | 05:50 AM
265 might alittle to wide for a 19x8.5
Old Jul 4, 2009 | 08:19 AM
Yes, a 265 is a little too wide for an 8.5", but it will fit. TurTLe* is running 265's on his Track Edition Wheels and they're 8.5" in the back.
Picture Share
Feb 4, 2018 12:41 PM
TurTLe*
Sep 29, 2015 01:43 PM
DRG35R
Sep 16, 2015 05:33 AM
